Guest WRPS515 Posted August 12, 2022 Report Posted August 12, 2022 setting up Wouxun kg-1000g CTCSS and DCS codes for privacy. The other radios are Midland and Bofang. Is there a simple way to do this? Quote
BoxCar Posted August 12, 2022 Report Posted August 12, 2022 Whatever code or codes you decide on must be the same value(s) in the other radios for each channel you use. I recommend setting ONE channel as your family channel and leave the others a default values or as needed for repeaters. Quote
OffRoaderX Posted August 12, 2022 Report Posted August 12, 2022 and, dont forget, if you want privacy as you've mentioned, using codes will not give you any. fe2o3 and kirk5056 2 Quote
KAF6045 Posted August 13, 2022 Report Posted August 13, 2022 23 hours ago, Guest WRPS515 said: setting up Wouxun kg-1000g CTCSS and DCS codes for privacy. The other radios are Midland and Bofang. Is there a simple way to do this? Other than having manuals available -- I know at least some Midland units just use a linear numbering scheme for available tones, which means having to look up the tone/code in the manual to find the index number for the radio. Just don't think they mean "privacy" as in a telephone. The tones work more as a fence, keeping others out of your radio if they don't send the tone you want. Anything sent from your radio will be received by anyone whose radio is set to "NO TONES" on receive (or matches your selection). Quote
