WRUJ939 Posted September 7, 2022 Report Posted September 7, 2022 I just recieved access to use the local repeaters. I can hear traffic on them but can not seem to transmit. When i was granted acess there were multible (dbl?) numbers after the frequencies. are these the tones? I am running Baofeng UVR-5 handsets. Quote
KAF6045 Posted September 7, 2022 Report Posted September 7, 2022 33 minutes ago, WRUJ939 said: I just recieved access to use the local repeaters. I can hear traffic on them but can not seem to transmit. When i was granted acess there were multible (dbl?) numbers after the frequencies. are these the tones? I am running Baofeng UVR-5 handsets. Most likely. Were they the same or different values? Do they match the table of tones available on the radio. Also, make sure you are using a channel configured for repeaters (+5MHz offset -- so transmit on 467.xxxx, receive on 462.xxxx). For initial testing, just set the radio to send (encode) the tone, leave receive (decode) to None. After confirmation, you can try adding the receive tone (this may be useful if you are getting a lot of kids with FRS radios transmitting on the same 462.xxxx frequencies -- you won't be hearing them, though if close by they could still block repeater traffic). SteveShannon 1 Quote
WRUJ939 Posted September 7, 2022 Author Report Posted September 7, 2022 Thank you, I will try that out. Quote
