davidloudermilk Posted September 8, 2022 Report Share Posted September 8, 2022 So here are two files from my read from my Icom CY repeater RX/TX file is the main transmitter the other is the receiver. The main question is the CTone seems to be set to digital in the Banks column but on the expert mode setting the CTCSS is 88.5 How does this work with my handhelds to work with the system? https://drive.google.com/drive/folders/1SAfB1Xa2OapIMac8W439H6GKPgqXl76O?usp=sharing Quote Link to comment Share on other sites More sharing options...
1 gortex2 Posted September 8, 2022 Report Share Posted September 8, 2022 OK. So I looked at your files. You have problems. RX Radio - Currently is set for 457.550. That needs to be 467.550 for GMRS. The RX PL/DPL is 265N. In your portable you need to set Encode to DPL/DCS and 265N TX Radio - Currently is set for 452.550. This also needs to be changed to 462.550 for GMRS. The PL/DPL is the same (265N) on the TX Radio. Your Portable would use 265N also. So change frequencies, Tune Duplexer and have fun. The CY121 Repeater is a nice little box and ideal for home repeater use. Quote Link to comment Share on other sites More sharing options...
davidloudermilk
1 answer to this question
