MichaelLAX Posted December 27, 2022 Report Posted December 27, 2022 58 minutes ago, WRVE426 said: I will go with CHIRP which I trust much more. In CHIRP, just under Memories in the upper left hand corner, see if there is a Settings Mode and within that, an Advanced Settings and if, when clicked, there is an option to change the ID line from Wouxun KG-935G to WRVE426. Otherwise you might have to use the Wouxun software for those types of settings. Sab02r and Andrei 2 Quote
Andrei Posted December 27, 2022 Author Report Posted December 27, 2022 21 hours ago, MichaelLAX said: In CHIRP, just under Memories in the upper left hand corner, see if there is a Settings Mode and within that, an Advanced Settings and if, when clicked, there is an option to change the ID line from Wouxun KG-935G to WRVE426. Otherwise you might have to use the Wouxun software for those types of settings. yes, thank you, that worked perfectly Quote
RickSnowden Posted March 29, 2024 Report Posted March 29, 2024 My windows 10 would not load the driver, had to down load it and install, was easy to do and works fine now. Quote
