WRVZ984 Posted February 3, 2023 Report Posted February 3, 2023 I've recently been given permission to use a local repeater in my area. Unfortunately, I have not been able to connect. I've put in the frequency and DPL tone in my handheld but no success. I've left a comment with the owner to find out if this repeater is currently up and running. Is there anything that I might be missing here? Quote
OffRoaderX Posted February 3, 2023 Report Posted February 3, 2023 are you sure you are using the correct channel "pair"? Its not just "the frequency". CP650, SteveShannon, WRVZ494 and 1 other 4 Quote
CP650 Posted February 3, 2023 Report Posted February 3, 2023 18 hours ago, OffRoaderX said: are you sure you are using the correct channel "pair"? Its not just "the frequency". This is my first question as well. Are you using the correct split repeater channels or offset frequencies? Then my next question would be are you sure you can reach that repeater and open it up from your location with your equipment. More information will help. What equipment are you using, how far is the repeater, what is the terrain between you and said repeater? Quote
