WRVZ494 Posted February 3, 2023 Report Posted February 3, 2023 Hello, newb here, I did try to search so maybe this hasn't been asked before and is appropriate. Is there a GMRS repeater that provides some coverage in the Death Valley National Park area? I tried to search with the map feature, and if I'm doing it correctly, it doesn't appear there is. But I figured I'd as and it was a reason to post a question! Quote
WRUU653 Posted February 3, 2023 Report Posted February 3, 2023 1 hour ago, WRVZ494 said: Hello, newb here, I did try to search so maybe this hasn't been asked before and is appropriate. Is there a GMRS repeater that provides some coverage in the Death Valley National Park area? I tried to search with the map feature, and if I'm doing it correctly, it doesn't appear there is. But I figured I'd as and it was a reason to post a question! Looking at the map I don’t see any. There are quite a few in the outlying area and maybe someone here has real world experience in the area. I would certainly try if I were out there just to see if it were possible to reach some. Depending on where out there you are you could get lucky. I would like a Garmin inreach with me if you’re thinking middle of nowhere safety. gortex2 and WRVZ494 1 1 Quote
WRVZ494 Posted February 3, 2023 Author Report Posted February 3, 2023 Thanks at least I wasn’t searching wrong! I take a ZOLEO with me when I’m out there well anywhere outside of normal cell coverage. The next time I heard out there I’ll definitely test things out and see what I can connect to. Just didn’t know if someone already knew of one. WRUU653 1 Quote
