WRWG621 Posted April 1, 2023 Report Posted April 1, 2023 https://mygmrs.com/repeater/4438 I'm trying to access this repeater. How do I program the tone? Quote
0 nokones Posted April 1, 2023 Report Posted April 1, 2023 13 minutes ago, WRWG621 said: https://mygmrs.com/repeater/4438 I'm trying to access this repeater. How do I program the tone? Program your portable or mobile to transmit on 467.575 MHz with DPL 311 encode and receive on 462.575 MHz with DPL code 311 decode. More than likely, this repeater may be set for wideband operation. Since there is notation, you should program this frequency pair for wideband. What make model radio are you using? You might have to convert the DPL 311 to a programming code for your specific make radio. Quote
0 WRWG621 Posted April 1, 2023 Author Report Posted April 1, 2023 I'm brand new and using a Tenway gm-55. I've downloaded the software and have my channels correct. I'm confused on how to set the tone. Quote
0 WRWG621 Posted April 1, 2023 Author Report Posted April 1, 2023 3 minutes ago, nokones said: Program your portable or mobile to transmit on 467.575 MHz with DPL 311 encode and receive on 462.575 MHz with DPL code 311 decode. More than likely, this repeater may be set for wideband operation. Since there is notation, you should program this frequency pair for wideband. What make model radio are you using? You might have to convert the DPL 311 to a programming code for your specific make radio. Do I use the CTCSS/CDCSS encode and decode to set the 311 tone? Quote
0 nokones Posted April 1, 2023 Report Posted April 1, 2023 Just now, WRWG621 said: Do I use the CTCSS/CDCSS encode and decode to set the 311 tone? Not CTCSS. What radio are trying to program. Quote
0 WRWG621 Posted April 1, 2023 Author Report Posted April 1, 2023 5 minutes ago, nokones said: Not CTCSS. What radio are trying to program. It's a Tenway GM-55 and I think I got my problem solved. I appreciate it Quote
WRWG621
5 answers to this question
