Dustynevada Posted April 8, 2023 Report Posted April 8, 2023 Hello everyone, my problem is on the radioddity DB25 – G, when I am looking at a line item in channel mode and then I change it to frequency mode. It is showing a frequency in the one for 140.000 range. All channels seem to have this such as 144.027 for example. I know it is a nube issue and have read the manual but having trouble with programming. Any help would be appreciated. Thanks Quote
SteveShannon Posted April 8, 2023 Report Posted April 8, 2023 When you change from channel or memory mode to frequency mode, the frequency does not correlate to the channel. It’s the last frequency you were on. For instance, you tune your radio to 443.675 and then you change to memory mode. The last channel you were on in channel mode is where you’ll be. Then change to a different channel. Then, if you change back to frequency mode, you’ll be right back at 443.675, the frequency you were using before changing modes. WRUU653 1 Quote
Dustynevada Posted April 9, 2023 Author Report Posted April 9, 2023 Thank you, Steve. SteveShannon 1 Quote
