Radioddity GM-30 Programming Software - Cannot change incorrect repeater transmit values for DIY channels
Recently purchased Radioddity GM-30
Firmware V06.03.009
Radioddity GM-30 GMRS Radio Program Software SAIN 3 LLC Version 1.05
The programming software allows modification to white cells. The gray cells are write protected. It is not possible to change ANY transmission frequency.
Channels DIY-4, DIY-12 and DIY-20 have the correct receive / transmit values for 462.6250 / 467.6250 repeaters.
Channels DIY-8, DIY-16 and DIY-24 have the correct receive / transmit values for 462.7250 / 467.7250 repeaters.
All other DIY channels have incorrect transmit frequencies which cannot be modified with this programming software.
The GM-30 cannot be programmed with Chirp.
6 answers to this question
Firmware V06.03.009
Radioddity GM-30 GMRS Radio Program Software SAIN 3 LLC Version 0.05
The programming software allows modification to white cells. The gray cells are write protected. It is not possible to change ANY tranmission frequency.
I think we’ve heard of this problem before.  I don’t know what the resolution was, if there was one.
Unfortunately, there isn't any 467.6000 value in any DIY channel. 3 repeaters in my county are 462.6000 / 467.6000. I can program 1 of them in RPT-3. Not a useful radio where I live.
DIY Channel Cleanup
Remove DIY channels with 467.52500 in the TX Freq column. GMRS repeaters do not transmit on this frequency.
Modify the DIY channels with the mis-matched RX / TX pair by changing the RX value.
