just turned on new EVX-R70 repeater to program and the fan is more than a tad obnoxious. I don’t have a dedicated shack or rack closet, so the noise will be a problem.
I cracked the case and it appears to be a fairly standard 12VDC 120MM box fan with a 4 wire/ 4 pin connector.
can anyone think of a reason why I can’t swap this out for a low noise computer fan? This repeater won’t be driven hard, so heat dissipation isn’t a huge concern?
I haven’t seen this pin config before, so may have to experiment if requiring. Has anyone done this?
zargnut
Hi,
1 answer to this question
