GuyBagot Posted May 17, 2023 Report Posted May 17, 2023 How do I get a CDM1250 to power on when it gets power? (with out pressing the power button) Quote
0 kidphc Posted May 17, 2023 Report Posted May 17, 2023 You will need the accesory cable and connector use the remote on wire and tap into a 12v switchable powered source (car am/fm radio wire/fuse is the favorite).Then go into cps and configure the ignition sense under radio information/accessory configuration/ignition sense type.Then, when ever the ignition energizes the wire (in example above car radio). It will auto turn the radio on. Turn off the car and it should go off. Unless the remote wire is connected to a power delay accessory. Then it will turn off when the wire is not powered, usually at driver door open or some pre-configured time out.EDITIED to clarify things because I suck at explaining things the first time around.Sent from my SM-S901U using Tapatalk WRCQ487 1 Quote
0 WRCQ487 Posted May 18, 2023 Report Posted May 18, 2023 https://www.ebay.com/itm/263779287455?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=QW_esGMBRM2&sssrc=2349624&ssuid=U2rvV5ATT8G&var=&widget_ver=artemis&media=MORE I'm sure you can find them cheaper but that is what you are looking for. SteveC7010 and kidphc 2 Quote
GuyBagot
2 answers to this question
