old coax rgb/u 95 foam
Bamishere
Sounds like it's some type of oddball 95 ohm coax.  What's the application?  I sure wouldn't use it for any GMRS applications (which almost always requires 50 ohm cable).  Could you even source proper connectors for it?
Old coax is more likely to be the cause of problems than the solution, at least in my experience.
