Gmrs glass mount antenna on plexiglass?
Due to a lack of experience, I have a unique question.
I have used glass mount antennas on my trucks in the past. Performance losses were marginal, antenna damage was eliminated.
My Utv has a plexiglass rear window. Has anyone put a glass mount Gmrs antenna on plexiglass? How well did it work?
I know it's a desperate question, but I suffer PTSD from several traumatic antenna losses.
Thank you
WRJA397
4 answers to this question
Thank you
WRJA397
There’s no reason to expect different results for plexiglass than you experience with glass. I would expect identical results.
Of course it’s relatively easy to just drill through the plexiglass or clamp the mount to a roll bar.
Best wishes as you work through this traumatic experience. 😄
More importantly make sure you use an antenna that doesn’t rely on a ground plane.
Thanks for the post.
Any suggestions on an nmo type that would easily tip back when hit. It's looking like this will be an adventure into the unknown. When I find a piece of clean 1/4" plexiglass to do a mockup with an old dual band setup. This will save an ugly scare if it fails. I will report back on the results when I get it done.
The two of the antennas that met a tragic death were comet SBB5. The best dual band ever.😂
P.E. (retired)?
Thanks
WRJA397
P.E. (retired)?
Thanks
WRJA397
Pretty much anything with a spring.  I like the Laird antennas, and any of their 450-470 MHz antennas that end with an "N" will be a no ground plane required, and the "R" or "S" indicates a rubber (elastomer) or stainless spring, respectively.  The "BB" models are all black, and the "B" are black base and stainless.
Examples:
https://theantennafarm.com/shop-by-categories/shop-all/mobile-antennas/300-512-mhz-uhf/no-ground-plane-antennas/3232-laird-connectivity-bb4505cns-detail
https://theantennafarm.com/shop-by-categories/shop-all/mobile-antennas/300-512-mhz-uhf/no-ground-plane-antennas/3236-laird-connectivity-bb4502ns-detail
https://theantennafarm.com/shop-by-categories/shop-all/mobile-antennas/300-512-mhz-uhf/no-ground-plane-antennas/6533-laird-connectivity-b4502nr-detail
https://theantennafarm.com/shop-by-categories/shop-all/mobile-antennas/300-512-mhz-uhf/no-ground-plane-antennas/6536-laird-connectivity-bb4502nr-detail
https://theantennafarm.com/shop-by-categories/shop-all/mobile-antennas/300-512-mhz-uhf/no-ground-plane-antennas/3233-laird-connectivity-b4505cns-detail
P.E. (retired)?
Thanks
WRJA397
Retired (best job ever!)
I like my SBB5. It’s not good for GMRS, but it’s great for 2m and 70cm. But it doesn’t have a spring or even a folding whip. Comet does have spring bases though. I haven’t researched them.
