Guest Mike m Posted August 30, 2023 Report Posted August 30, 2023 I'm trying to setup weather alert on my wouxun kg-935g plus, do I have to listen to 24 hour weather to get weather alert , did I miss a step ? I'm using 162.47500 Quote
WRHS218 Posted August 30, 2023 Report Posted August 30, 2023 You shouldn't have to. You choose the weather channel you want to monitor which is only available in Area A. You can press and hold the AREA button for 2 seconds to enter weather mode. Once you choose the NOAA channel to monitor you can get out of weather mode and go to menu 7 and turn on weather alert. After that go to menu 23 to choose what kind of alert you want, there are 5 choices. Once you are done with that you are done. When the radio is in standby, you are not actively TXing, and there is an alert for the NOAA channel you selected the radio will display the alert according to the choice you made for weather notification. You do not have to be in the weather mode. Sab02r, WRYJ580, SteveShannon and 2 others 5 Quote
