WRYI436 Posted September 10, 2023 Report Posted September 10, 2023 Just to put this out there. If you purchased a Baofeng handheld GMRS radio and want to program it using software, use the new CHIRP_NEXT software, it works so much better with Baofeng Radio's. Also make sure you have the right Prolific Driver installed. Hope this helps Links below Chirp_NEXT https://trac.chirp.danplanet.com/download?stream=next Prolific https://www.miklor.com/COM/software/P3200.zip Also Randy has a great video for programing here Quote
OzzyWRYR584 Posted September 11, 2023 Report Posted September 11, 2023 Brand new to GMRS and have a couple UV-9g radios. Got them all setup and running great on CHIRP. Once you fool around with it a bit, it is fairly easy to use. Kinda rough to begin with. The video tutorials are a huge help. Quote
