Good evening! I have been using chirp to program a UV50x2 and each time I upload my desired channels, frequencies, tones etc. I find that it is almost as if the spreadsheet shifted and assigned the frequency from the column above and so on down the line. Has anyone else experienced this? I COULD go through and program each of the frequencies against what I want as there aren't many channels I intend to listen to or use but it seems to defeat the purpose a bit. One of the benefits I suppose would be having a channel name and then use the handset to work through each freq & tone (freakin tone....see what I did there?). Thanks for any info you may be able to help me out with! I'll try to upload a screenshot of what I'm looking at soon!
WRZR436
David
Wrzr436
1 answer to this question
