For those the Inland Empire California: I'm having problems configuring the following two repeaters to send and receive.  Can some who may has these settings please post a CHIRP image of their settings so I can correct what I entered. Note: when Delta 700 was active never had a problem connecting and receiving.  If doable throw in Verdugo. I submitted a request for permission to access the repeater but never receive a reply.  Thank you for your time.  73!
Ranchino & Verdugo
Rick
1 answer to this question
Ranchino is DCS23 IN, and optionally OUT and is on 600.
The range on Ranchino is fairly limited and it has several holes in coverage due to hills/mountains - Delta was in a much better location and could be reached from a much wider area, so it is possible you are out of range of Ranchino.  Where are you located?
