I am using the URIxB with the RT97S on GMRS live. When i run the Simple USB tune tool and use option 2) "Set Rx Voice Level (using display)" and key up the level bar doesn't move no matter how loud I talk.
If I change L) "Change CTCSSFROM Mode (currently "no")" to "usbinvert" and run V) "View COS, CTCSS and PTT Telemetry using real-time display" the CTCSS will change from "CLEAR" to "KEYED" when I PTT. So to me the URI is hearing something.
Any help would be apricated.
Here are my current setting. (Pretty much default)
USB device String: 1-1.1.2:1.0
Card is: 0
Name is: usb
Rx Level: 500
Rx ondelay: 0
Rx audio-delay: 0
Tx A Level: 500
Tx B Level: 500
Tx DSP Level: 850
preemphasis: no
deemphasis: no
plfilter: yes
dcsfilter: no
rxboost: no
PTT: Active LOW
PTT status: Un-Keyed
CTCSS (input): Ignored
COS (input): CM108/CM119 Active LOW
COS (test): Un-Keyed
COS (composite): Un-Keyed
WSAP632
Card is: 0
Name is: usb
Rx Level: 500
Rx ondelay: 0
Rx audio-delay: 0
Tx A Level: 500
Tx B Level: 500
Tx DSP Level: 850
preemphasis: no
deemphasis: no
plfilter: yes
dcsfilter: no
rxboost: no
PTT: Active LOW
Press <enter> to continue.
Thank you.
0 answers to this question
