Audio issues with UBIxB and Retevis RT97S.
WSAP632
 I am using the URIxB with the RT97S on GMRS live. When i run the Simple USB tune tool and use option 2) "Set Rx Voice Level (using display)" and key up the level bar doesn't move no matter how loud I talk.
If I change L) "Change CTCSSFROM Mode (currently "no")" to "usbinvert" and run V) "View COS, CTCSS and PTT Telemetry using real-time display" the CTCSS will change from "CLEAR" to "KEYED" when I PTT. So to me the URI is hearing something.
Any help would be apricated.
Here are my current setting. (Pretty much default)
USB device String:       1-1.1.2:1.0
Card is:         0
Name is:         usb
Rx Level:        500
Rx ondelay:      0
Rx audio-delay:  0
Tx A Level:      500
Tx B Level:      500
Tx DSP Level:    850
preemphasis:     no
deemphasis:      no
plfilter:        yes
dcsfilter:       no
rxboost:         no
PTT:             Active LOW
PTT status:      Un-Keyed
CTCSS (input):   Ignored
COS (input):     CM108/CM119 Active LOW
COS (test):      Un-Keyed
COS (composite): Un-Keyed
Press <enter> to continue.
Thank you.
Link to comment
Share on other sites
0 answers to this question
There have been no answers to this question yet
