WSBU243 Posted March 13, 2024 Report Posted March 13, 2024 Hey guys, I'm new here as well as into gmrs and I have some questions about programming a Radioddity GM30. I just got this thing and my brain hurts now from trying to figure this thing out. At this point with it I think learning Chinese is probably easier than this Anyways, my issue is I have approved access to a repeater near me that requires a tx of 467.650 and a rx of 462.575. The tx frequency is already programmed into the radio which I found along with understanding that the radio comes pre set with the correct offset which should then convert over to 462.650,is that correct? and if so, how do I get it to change to the 462.575 that the repeater requires? Do I need to be in channel mode or vfo mode to change anything with these preset channels... I'm so lost on all of this any and all help would be so greatly appreciated. Thank you so much, Ronnie (WSBU243) Quote
WRXB215 Posted March 13, 2024 Report Posted March 13, 2024 I already answered you on your other post. Please don't double post. If you need to change something, just edit the original post. Quote
