WSAN654 Posted March 17, 2024 Report Posted March 17, 2024 Radioddity G30 Simplex 7 to 10 miles.via repeater 30 to 70 miles west Texas and USB charging and we have 7 of these for work.j Just excellent radios. Baofeng 5RX excellent all round for the price considering my main HT is FT70DR Baofeng K5 plus Cumbersome and too large- tall and thick but if your not going to put on your belt it's excellent for base station or attached to a mag mount in your car USB charging and battery life excellent. Quote
WRYC373 Posted March 17, 2024 Report Posted March 17, 2024 Yep the GM-30s / GM-15 Pro are some of the best sub 100$ GMRS radios and I'm seeing more out there in the wild. I think between friends and family we have 8 or so. Super easy to use and charge. WSDA973 and WSAN654 2 Quote
WSDA973 Posted May 29, 2024 Report Posted May 29, 2024 I just got the Baofeng GM-15 pro and its an awesome little radio, just at Witts end with the programming software not allowing you to program diy Channels as additional repeaters. amaff 1 Quote
amaff Posted May 29, 2024 Report Posted May 29, 2024 The super restrictive programming is probably my biggest annoyance with a lot of the cheaper GMRS radios. My more expensive ones (in this case, KG-905Gs, so not SUPER high end stuff) let me program in what I want where I want, and enforce the GMRS rules properly for those frequencies. As far as I can tell, I could put a repeater channel in every slot of the radio. Pretty much everything else I have is jailbroken (with the appropriate rules programmed in manually) so I can set them up the way I want to. There's nothing in the GMRS rules that says "the radio can ONLY HAVE 22 simplex channels, 8 repeater channels, and if you're feelin frisky, a handful of DIY channels" WRXR255 1 Quote
Guest Posted May 29, 2024 Report Posted May 29, 2024 1 hour ago, amaff said: The super restrictive programming is probably my biggest annoyance with a lot of the cheaper GMRS radios. My more expensive ones (in this case, KG-905Gs, so not SUPER high end stuff) let me program in what I want where I want, and enforce the GMRS rules properly for those frequencies. As far as I can tell, I could put a repeater channel in every slot of the radio. Pretty much everything else I have is jailbroken (with the appropriate rules programmed in manually) so I can set them up the way I want to. There's nothing in the GMRS rules that says "the radio can ONLY HAVE 22 simplex channels, 8 repeater channels, and if you're feelin frisky, a handful of DIY channels" I agree totally. Even the same ccr that are not gmrs locked are very programable. It’s why I won’t own a gmrs only. Quote
