Guest Tom Posted May 7, 2024 Report Posted May 7, 2024 Hello- I am in need of a charger for Standard Horizon 280S. Are there after market models which could work? They seem to be hard to find. Thank you. Quote
SteveShannon Posted May 7, 2024 Report Posted May 7, 2024 8 minutes ago, Guest Tom said: Hello- I am in need of a charger for Standard Horizon 280S. Are there after market models which could work? They seem to be hard to find. Thank you. Assuming you don’t need the cradle, but just the charger: Accessory USA AC Battery Charger for Yaesu Vertex Standard NC-88B PA-44B NC90B PA48B https://a.co/d/iChxhm1 Quote
Guest Tom Posted May 7, 2024 Report Posted May 7, 2024 Thanks- I I searched E bay finding non 280S model chargers. Anyone know which model chargers fit the 280s? Quote
Guest entire assembly Posted May 7, 2024 Report Posted May 7, 2024 Clarification - I need the cradle / charger- entire assembly. Quote
WRQC527 Posted May 7, 2024 Report Posted May 7, 2024 7 minutes ago, Guest entire assembly said: Clarification - I need the cradle / charger- entire assembly. Is this your radio? The HX280S marine radio? https://www.standardhorizon.com/indexvs.cfm?cmd=DisplayProducts&ProdCatID=85&encProdID=8A20187F57E11E685F4BEB4E09111DB3&DivisionID=3&isArchived=1 Quote
Guest Standard Horizon 280s Posted May 7, 2024 Report Posted May 7, 2024 Yes, that is my model, 280s Quote
SteveShannon Posted May 7, 2024 Report Posted May 7, 2024 42 minutes ago, Guest entire assembly said: Clarification - I need the cradle / charger- entire assembly. The cradle is CD-46. When available it’s sold separately. It’s apparently in poor supply. I couldn’t find one available. The charger for 110 volts AC is NC90b. It’s available. Quote
SteveShannon Posted May 7, 2024 Report Posted May 7, 2024 A review of the CD-48 charger, which is currently available on Amazon, indicates that it is interchangeable with the CD-46: Standard Horizon CD-48 Charge Cradle F/hx380 https://a.co/d/cZeF0R7 Quote
Guest Thank you Posted May 7, 2024 Report Posted May 7, 2024 Thank you for your tremendous support! Quote
