Every node I try to connect to immediately disconnects. Anybody have any ideas? It is a fresh setup and my node is listed on the repeater map and the network map. My repeater is working locally, but I can't connect to any other node. The port-forward is set up properly. The repeaterfinder.sh script has the correct username and password. The registration line was put in the iax.conf file, and asterisk was restarted before running the repeaterfinder.sh script. I've allowed several days for the new node update to go out to the other nodes. Any suggestions are appreciated.
I turned one of my nodes off (23301) for the time being to stop them from bombarding the registration server, which is returning the errors below.
Can somebody try to connect to node 23302 and let me know what happens? Both my nodes are experiencing the same problem.
Running <sudo asterisk -r> and seeing the following errors non-stop:
Connected to Asterisk GIT Version adaec47 currently running on node-23301 (pid = 520)
WRZK971
[May 18 21:08:15] NOTICE[585]: chan_iax2.c:9712 socket_process: Registration of '23301' rejected: '<unknown>' from: '34.194.144.228'
[May 18 21:09:05] NOTICE[589]: chan_iax2.c:9712 socket_process: Registration of '23301' rejected: '<unknown>' from: '34.194.144.228'
[May 18 21:09:55] NOTICE[593]: chan_iax2.c:9712 socket_process: Registration of '23301' rejected: '<unknown>' from: '34.194.144.228'
[May 18 21:10:45] NOTICE[587]: chan_iax2.c:9712 socket_process: Registration of '23301' rejected: '<unknown>' from: '34.194.144.228'
[May 18 21:11:35] NOTICE[591]: chan_iax2.c:9712 socket_process: Registration of '23301' rejected: '<unknown>' from: '34.194.144.228'
[May 18 21:12:25] NOTICE[585]: chan_iax2.c:9712 socket_process: Registration of '23301' rejected: '<unknown>' from: '34.194.144.228'
8 answers to this question
