WSCU736 Posted May 23, 2024 Report Posted May 23, 2024 I know a HT has 5 watts. How would it do with a base antenna? The antenna is about 17' high. I know there is a lot of varibels. Just in general Quote
1 WRWE456 Posted May 23, 2024 Report Posted May 23, 2024 Line of sight between antenna's is most important. I can reach 91 miles to a repeater with my HT with my rooftop antenna and living on a hill with clear line of sight to the repeater. Quote
0 kidphc Posted May 23, 2024 Report Posted May 23, 2024 Much better.Remember UHF is line of sight. So the higher the antenna the better it will work (see).Power comes into play to overcome distance and obstructions (like leaves and trees).Sent from my SM-S901U using Tapatalk WSCU736 1 Quote
0 Guest Posted May 23, 2024 Report Posted May 23, 2024 I lived with a comet712 on the roof hooked to my hand held for a while before my base unit got installed. It way more then doubled my distance. Quote
0 kidphc Posted May 23, 2024 Report Posted May 23, 2024 Should note: highly recommend a mag mount mobile antenna. Even with a handset it works well (cavet, your experience will vary). Well much better than ht inside of a car with the rubber duck antenna.It is also why we recommend sma to bnc adapters for the ht and bnc to so239 for the antenna.Sent from my SM-S901U using Tapatalk WSCU736 1 Quote
WSCU736
4 answers to this question
