nomaDicVentures Posted June 12, 2024 Report Posted June 12, 2024 all of a sudden i am getting a beep when i push PTT when trying to connect to repeaters- this did not happen before= Anyone know why>? Quote
0 OffRoaderX Posted June 12, 2024 Report Posted June 12, 2024 What kind of radio do you have? Have you made any changes to the radio recently? Have you tried turning the radio off/then back on? Quote
0 nomaDicVentures Posted June 12, 2024 Author Report Posted June 12, 2024 it is a tidradio h8- i have made no changes except to change squelch up and down to see if that fixed the issue, it did not- and certainly i turned it off and on Quote
0 OffRoaderX Posted June 12, 2024 Report Posted June 12, 2024 5 minutes ago, nomaDicVentures said: tidradio h8- i have made no changes except to change If one moment its working normally, then the next, just beeping, then something has gone horribly wrong. I would try doing a factory-reset and if that does not help, I would recommend contacting TidRadio Support. Quote
0 DenMRadio Posted June 15, 2024 Report Posted June 15, 2024 On 6/12/2024 at 11:10 AM, nomaDicVentures said: it is a tidradio h8- i have made no changes except to change squelch up and down to see if that fixed the issue, it did not- and certainly i turned it off and on So what channel? Is it one you've transmitted on before? The TD-H8 (the GMRS version) won't allow transmissions on channels above channel 52. Maybe the software is confused. Quote
nomaDicVentures
4 answers to this question
