I’m pretty sure the h8 does not have this function.  I’m pretty sure the h8 only has Bluetooth for programming and not audio.   I’d bet it’s the same for the h3.  But maybe not?
  • 3 weeks later...
3 hours ago, LeoG said:
On the side there are two connectors for the mic and programming.  One of them is the output to an external speaker.  Not sure which is which though.
It’s molded into the cover. The top jack is for the headphone. The bottom is for the microphone. Both are necessary for programming unless you’re using Bluetooth.
  • 4 weeks later...
Correct; The TID H8 has no audio/tx provisions for using  Bluetooth, unfortunately.
Reply to this topic...
