WSAB572 Posted June 22, 2024 Report Posted June 22, 2024 I was told you could paira bluetooth external speaker with the TID h-3 , but can not find any details on how to do that. Is there a Bluetooth menu on the H-3 ? Quote
Guest Posted June 22, 2024 Report Posted June 22, 2024 I’m pretty sure the h8 does not have this function. I’m pretty sure the h8 only has Bluetooth for programming and not audio. I’d bet it’s the same for the h3. But maybe not? Quote
LeoG Posted June 23, 2024 Report Posted June 23, 2024 It does not have this capability. The bluetooth is strictly for accessing the programming software from a phone. TrikeRadio 1 Quote
WSAB572 Posted July 9, 2024 Author Report Posted July 9, 2024 is there a way to connect the th3 with speaker.. what type of connector ? Quote
LeoG Posted July 9, 2024 Report Posted July 9, 2024 On the side there are two connectors for the mic and programming. One of them is the output to an external speaker. Not sure which is which though. WSAB572 1 Quote
SteveShannon Posted July 9, 2024 Report Posted July 9, 2024 3 hours ago, LeoG said: On the side there are two connectors for the mic and programming. One of them is the output to an external speaker. Not sure which is which though. It’s molded into the cover. The top jack is for the headphone. The bottom is for the microphone. Both are necessary for programming unless you’re using Bluetooth. WRHS218 and RayDiddio 2 Quote
Jaay Posted August 7, 2024 Report Posted August 7, 2024 On 6/22/2024 at 4:44 PM, WRXP381 said: I’m pretty sure the h8 does not have this function. I’m pretty sure the h8 only has Bluetooth for programming and not audio. I’d bet it’s the same for the h3. But maybe not? Correct; The TID H8 has no audio/tx provisions for using Bluetooth, unfortunately. Quote
LeoG Posted August 7, 2024 Report Posted August 7, 2024 H3 is the same. Bluetooth is for programming only. TrikeRadio 1 Quote
TrikeRadio Posted August 7, 2024 Report Posted August 7, 2024 On 6/22/2024 at 1:58 PM, WSAB572 said: I was told you could paira bluetooth external speaker with the TID h-3 , but can not find any details on how to do that. Is there a Bluetooth menu on the H-3 ? nope SteveShannon 1 Quote
