CALO50 Posted July 5, 2024 Report Posted July 5, 2024 Maybe it’s supposed to function this way? Activate Area B as the Primary “MAIN” Scan in SE mode Signal detected Scan stops and I listen to chatter Activate Area A as the Primary “MAIN” Chatter from Area B can still be heard after Area A is activated as the Primary “MAIN” What other details/settings would be helpful to evaluate? Quote
0 WRDU469 Posted July 6, 2024 Report Posted July 6, 2024 This sounds right from my experience. If scanning in SE mode, the scan stops on signal detection. If you have TDR on (allowing for duel display), then I believe you can duel receive as long as you have duel receive enabled. I only see the option to do this in the desktop software like RT Systems. The scan modes in the manual are not correct. I reported this back to "buy two way radios" but was just told they will tell Wouxun. If you scan in CO mode, when signal is detected, it stops, then resumes roughly 3 seconds after signal is lost. In TO mode when signal is detected, it stops and then scanning just resumes in a few seconds regardless of signal loss or not. In TO mode you have to carry out a function to prevent it from moving along in the scan such as hit Exit. Not sure if this was helpful or not. Quote
0 DenMRadio Posted July 6, 2024 Report Posted July 6, 2024 That's how it works. Both areas can receive at the same time unless you turn off Dual Display, using the TDR key. Then, with TDR off, you can still switch between active areas with the Area key. Quote
0 WRUU653 Posted July 6, 2024 Report Posted July 6, 2024 I personally don’t like hearing two channels at once so I turn simultaneous receive off. You can still use duel display but only hear one at a time. SteveShannon, WRHS218 and CALO50 3 Quote
0 CALO50 Posted July 6, 2024 Author Report Posted July 6, 2024 9 hours ago, WRUU653 said: I personally don’t like hearing two channels at once so I turn simultaneous receive off. You can still use duel display but only hear one at a time. Excellent! This is exactly what I was looking for. WRUU653 1 Quote
CALO50
Scan in SE mode
Signal detected
4 answers to this question
