LEO757 Posted September 30, 2024 Posted September 30, 2024 I'm a retired law enforcement officer and although not new to two way radios, I am new to GMRS, and will be using the system we recently purchased for camping and power outages mostly. The rig is a Motorola XPR 4350, a "silver box" with two lines in and 8 lines out to the repeater and and an SVR 250 UHF repeater. It is likely pretty powerful so I'm told. Looking for a local expert who can help to program the radio to 8 GMRS channels and get the repeater up & running here in Fox Hill. I also have a (25 watt?) Motorola Radius mobile/base with 8 each GMRS and repeater channels, and want to learn how to get it up and running. With this radio I have a home roof mounted 4 foot fiberglass UHF antenna. Any advice or assistance with getting these things off the ground would be appreciated. I also have 3 Motorola M1225 VHF small form factor mobile radios that I would like to get rid of. Feel free to email me. highway@dr.com Quote
LeoG Posted September 30, 2024 Posted September 30, 2024 Specs say it's a 2 watt output. TRANSMITTER VHF UHF- Frequency Range 150–174 MHz 450–470 MHz 405–425 MHz➊ RF power out 250mW - 2W 250mW - 2W Spurious emissions-50dBc-52dBc Frequency stability -30°~+60°C ±1.5 PPM ±1.5 PPM Modulation 11KOF3E/16KOF3E 11KOF3E/16KOF3E Hum and noise-40dB-40dB Audio response (300-3kHz) Flat or -6dB/octave Flat or -6dB/octave Audio distortion <3%@60% deviation <3%@60% deviation Local mic sensitivity 300mV - 5VPP 300mV - 5VPP FCC Type Acceptance LRUSVR-200VB LRUSVR-200UD Industry Canada Approval 2390 195 458A 2390 212 113A RECEIVERVHFUHF Frequency Range 150–174 MHz 450–470 MHz 405–425 MHz➊ RF sensitivity.35uV.35uV Squelch sensitivity .2uV to 2uV adjustable .2uV to 2uV adjustable Modulation acceptance ±3.75/±7.5kHz ±3.75/±7.5kHz Selectivity72dB60dB Spurious/image rejection 70dB 60dB IMD response60dB60dB Frequency stability 1.5 PPM 1.5 PPM Audio response (300-3kHz) Flat or +6dB/octave Flat or +6dB/octave Audio output Local Rx Audio 400 mW 8 Ohms@ 400 mW 8 Ohms@ <5% distortion <5% distortion ➊ Quote
gortex2 Posted September 30, 2024 Posted September 30, 2024 So very confused. You mention a XPR and also a SVR. I assume someone used the SVR for the RX side of the repeater and the XPR is being used as the TX ? Can you snap a picture. While that would work normally the SVR would be a different band than the XPR in the LMR world. Lots of them in service for vehicle extenders per say. Anyway if you can give us more info it would help. The XPR and the SVR use totally different software so you'll need software and cables for both. SVR may be a bit harder to find but its out there. Quote
MaxHeadroom Posted October 1, 2024 Posted October 1, 2024 15 hours ago, gortex2 said: So very confused. You mention a XPR and also a SVR. I assume someone used the SVR for the RX side of the repeater and the XPR is being used as the TX ? Can you snap a picture. While that would work normally the SVR would be a different band than the XPR in the LMR world. Lots of them in service for vehicle extenders per say. Anyway if you can give us more info it would help. The XPR and the SVR use totally different software so you'll need software and cables for both. SVR may be a bit harder to find but its out there. That is how I would do it - use the XPR as the transmitter and the SVR as the receiver - make sure both are programmed only to one channel so no one can veer them off-course and where a duplexer isn't tuned. Did the same with a Motorola XTL5000 and Futurecom DVRS as a "camping repeater" and works well for the most part - but definitely keep duty cycle low on the repeater or the transmit radio WILL get hot. gortex2 1 Quote
