WSEZ761 Posted October 14, 2024 Posted October 14, 2024 I'm a noob. Heard of GMRS only 1 week ago. The only repeater in my area uses RPT-16, CH 24, RF 462.5750. I have Wouxun KG-935G Plus. Somehow I managed to Change RPT-16 to FR 462.550 and can't chang it back. Returning to factory settings has not fixed the problem. Now RPT-15 and 16 have the same frequency. I have no idea how I did it, nor how to fix it. Any ideas? Quote
0 Guest Posted October 14, 2024 Posted October 14, 2024 1 minute ago, WSEZ761 said: I'm a noob. Heard of GMRS only 1 week ago. The only repeater in my area uses RPT-16, CH 24, RF 462.5750. I have Wouxun KG-935G Plus. Somehow I managed to Change RPT-16 to FR 462.550 and can't chang it back. Returning to factory settings has not fixed the problem. Now RPT-15 and 16 have the same frequency. I have no idea how I did it, nor how to fix it. Any ideas? Get a programming cable and use rt systems and then you can do what ever you want. Quote
0 WRHS218 Posted October 14, 2024 Posted October 14, 2024 14 hours ago, WSEZ761 said: I'm a noob. Heard of GMRS only 1 week ago. The only repeater in my area uses RPT-16, CH 24, RF 462.5750. I have Wouxun KG-935G Plus. Somehow I managed to Change RPT-16 to FR 462.550 and can't chang it back. Returning to factory settings has not fixed the problem. Now RPT-15 and 16 have the same frequency. I have no idea how I did it, nor how to fix it. Any ideas? I have a 935G+ and changed RPT-16 from 462.5750 to 462.550 and saved the change. I then turned the radio of and back on and then checked to make sure the change was still there. Then I used the channel wizard to change RPT-16 back to 462.5750 and saved the change. Everything is normal again. I'm not sure what you did but I tried to reproduce your issue and couldn't. The Channel Wizard worked for me. WRXB215, WSEZ761 and WRUU653 3 Quote
0 WSEZ761 Posted October 15, 2024 Author Posted October 15, 2024 9 hours ago, WRHS218 said: I have a 935G+ and changed RPT-16 from 462.5750 to 462.550 and saved the change. I then turned the radio of and back on and then checked to make sure the change was still there. Then I used the channel wizard to change RPT-16 back to 462.5750 and saved the change. Everything is normal again. I'm not sure what you did but I tried to reproduce your issue and couldn't. The Channel Wizard worked for me. Thank you. I didn't realize I had to save my change. I don't remember making the change or using the save feature so I must have done it by accident. Anyhow, that was the step I was missing. WRUU653 1 Quote
0 WSEZ761 Posted October 15, 2024 Author Posted October 15, 2024 On 10/13/2024 at 7:51 PM, Socalgmrs said: Get a programming cable and use rt systems and then you can do what ever you want. Thanks. I have one in the mail. Quote
WSEZ761
4 answers to this question
