Guest StallionFire Posted October 14, 2024 Report Posted October 14, 2024 I have tried several times to register an account and after I put in my callsign to verify it comes up and says my callsign is already registered and shows me a green squared window with all my information in it. What is the next step. I do not have an account, and I cannot see where to proceed to finish registration or making an account I can log in with. It just keeps telling me under the block where you verify the callsign that my callsign is already registered. Shows red text. I even tried to log in and click on forgot password and it says no account is associated with my email. Am I doing something wrong ? Quote
Guest StallionFire Posted October 29, 2024 Report Posted October 29, 2024 Does anyone know how to register on the website? Is it broken? Quote
SteveShannon Posted October 29, 2024 Report Posted October 29, 2024 1 hour ago, Guest StallionFire said: Does anyone know how to register on the website? Is it broken? I doubt that it’s broken. I reported your post to the owner. He should be able to help you. Good luck! WRUU653 1 Quote
WRUU653 Posted October 29, 2024 Report Posted October 29, 2024 On 10/13/2024 at 9:27 PM, Guest StallionFire said: I have tried several times to register an account and after I put in my callsign to verify it comes up and says my callsign is already registered and shows me a green squared window with all my information in it. What is the next step. I do not have an account, and I cannot see where to proceed to finish registration or making an account I can log in with. It just keeps telling me under the block where you verify the callsign that my callsign is already registered. Shows red text. I even tried to log in and click on forgot password and it says no account is associated with my email. Am I doing something wrong ? The forum and the map/repeater site need to be logged into separately but will use the same passcode. TrikeRadio and RayDiddio 2 Quote
Guest StallionFire Posted October 29, 2024 Report Posted October 29, 2024 Ok, Thank you. I guess I will wait for an answer. I also sent an email about this with my Callsign. Quote
WSDU416 Posted December 24, 2024 Report Posted December 24, 2024 I'm having the same problem. Was there ever a resolution to this problem? I'm logged in and able to access the forums and my profile but when I try to access repeater information I'm asked to log in again. When I log in using the same username and password - I get an error message stating my credentials aren't valid. I've already reset my password so I know I'm using valid credentials. I emailed a moderator and messaged site support a few days ago. I like the map set up on this site but I can't use it. Is there another site anyone can recommend with the same info? I searched, I didn't see anything as well laid out and I'm chomping at the bit to get my families radio set up. Any guidance is appreciated. Lauren Quote
SteveShannon Posted December 24, 2024 Report Posted December 24, 2024 20 minutes ago, WSDU416 said: I'm having the same problem. Was there ever a resolution to this problem? I'm logged in and able to access the forums and my profile but when I try to access repeater information I'm asked to log in again. When I log in using the same username and password - I get an error message stating my credentials aren't valid. I've already reset my password so I know I'm using valid credentials. I emailed a moderator and messaged site support a few days ago. I like the map set up on this site but I can't use it. Is there another site anyone can recommend with the same info? I searched, I didn't see anything as well laid out and I'm chomping at the bit to get my families radio set up. Any guidance is appreciated. Lauren Merry Christmas Lauren and welcome. I’ve reported your post to Rich (the administrator/owner). He’s very helpful. WRUU653 1 Quote
WSDU416 Posted December 24, 2024 Report Posted December 24, 2024 7 minutes ago, SteveShannon said: Merry Christmas Lauren and welcome. I’ve reported your post to Rich (the administrator/owner). He’s very helpful. Thank you and Merry Christmas to you as well! WRUU653 and SteveShannon 2 Quote
Guest Account setup issues. Posted December 27, 2024 Report Posted December 27, 2024 While trying to setup a new account. I’m prompted to put in my call sign. When I put it in it pops up with an error message that my call sign is invalid. Quote
SteveShannon Posted December 27, 2024 Report Posted December 27, 2024 3 hours ago, Guest Account setup issues. said: While trying to setup a new account. I’m prompted to put in my call sign. When I put it in it pops up with an error message that my call sign is invalid. Are you sure you’re reading it right? We had one person try for months with a call sign that ended in l776. He was sure ended in 1776, when actually it was L776. All GMRS calls being issued now are 4 letters followed by 3 numerals. Like WROM258. Or perhaps you just got a new call sign and it doesn’t appear in the extract used by this site. That’s very common. Quote
WSDU416 Posted December 28, 2024 Report Posted December 28, 2024 13 hours ago, SteveShannon said: Are you sure you’re reading it right? We had one person try for months with a call sign that ended in l776. He was sure ended in 1776, when actually it was L776. All GMRS calls being issued now are 4 letters followed by 3 numerals. Like WROM258. Or perhaps you just got a new call sign and it doesn’t appear in the extract used by this site. That’s very common. I'm sure - because I'm logged in with my call sign in the forums but I can't see the repeater info. There's a disconnect between the two. You can see I'm logged into the forums with my call sign. Quote
WSDU416 Posted December 28, 2024 Report Posted December 28, 2024 5 minutes ago, WSDU416 said: I'm sure - because I'm logged in with my call sign in the forums but I can't see the repeater info. There's a disconnect between the two. You can see I'm logged into the forums with my call sign. Holy moly - it never crossed my mind that "username" for the repeater info is actually the call sign rather than my email address I use to log into the forums. I just tried my call sign instead of email address and it totally worked. I'm in! yay! RodB, SteveShannon and WRUU653 3 Quote
Guest Registering Issue Posted February 11 Report Posted February 11 Good Afternoon, I have repeatedly tried to register for an account over the past 3 weeks but have been unable to do so. I am receiving a Red Bar Warning that my GMRS Callsign (WSVG413) is not in the Database. I have verified that the callsign was copied correctly and is indeed valid with the FCC. Can someone please help?! Quote
