Faile to upload via Chirp with TD H3
I was unable to upload any changes to my TD H3 even though Chirp said it had. Same frequencies from original settings. It reads the radio fine. I am using the microphone connection.
Any help would be greatly appreciated.
I also tried via bluetooth and odmaster but it wouldn't read the radio.
weird,
Thanks, hal
6 answers to this question
3 hours ago, TrikeRadio said:
I use the USBc cable into the programing connection under the mic cable connection.
You are using a programming cable into the two prong microphone holes?
The USB cable is very convenient, eh? Wish my D878UV II Plus had the option.
I bought the programming cable for my TD-H3s but never use it. No need.
Just an FYI, I have several H3s and one H8 that I have reprogrammed several times using CHIRP on my Linux desktop, I've also used odmaster as well but find CHIRP much easier for programming.  I also found that I can program any HT I have, of which I have different variations of Baofengs, Wouxun, Tidradios, etc. using just the Wouxun PCO-009 WXUSB “Red” Programming Cable that came with my KV-UV9GX radio.  Current firmware version I'm using is 240702.
weird,
Thanks, hal
Hal, did you resolve the problem? Just wondering if the USB cable connection solved the issue instead of the "programming cable" if that is what you were using.
