WRKS933 Posted October 24, 2024 Report Posted October 24, 2024 On the repeater info here on mygmrs.com.... Is the tone next to the little box with an arrow pointing into it...... the tone I enter in my radio as the CTST Rx or Tx? Sorry. I couldn't decide if that arrow meant what the Repeater was sending out to my radio or what the Repeater wanted to hear FROM my radio. Quote
0 SteveShannon Posted October 24, 2024 Report Posted October 24, 2024 6 minutes ago, WRKS933 said: On the repeater info here on mygmrs.com.... Is the tone next to the little box with an arrow pointing into it...... the tone I enter in my radio as the CTST Rx or Tx? Sorry. I couldn't decide if that arrow meant what the Repeater was sending out to my radio or what the Repeater wanted to hear FROM my radio. It’s the input tone to the repeater, so it’s the output (TX) tone from your radio. Quote
0 stoutryan Posted October 24, 2024 Report Posted October 24, 2024 I too am having issues setting up to a repeater. The data I have is the repeater freq is 462.700 RX and TX tone is 210.7 but once I input that data into two radios I cant seem to communicate and I know I am doing something wrong. What I have done is; created T-CTCSS of 210.7 And R-CTCSS of 210.7 Can anyone tell me if these settings are correct. I'm using a midland unit that has the repeater channels already in so its an offset of +5 Any help here would be greatly appreciated Quote
0 SteveShannon Posted October 24, 2024 Report Posted October 24, 2024 8 minutes ago, stoutryan said: I too am having issues setting up to a repeater. The data I have is the repeater freq is 462.700 RX and TX tone is 210.7 but once I input that data into two radios I cant seem to communicate and I know I am doing something wrong. What I have done is; created T-CTCSS of 210.7 And R-CTCSS of 210.7 Can anyone tell me if these settings are correct. I'm using a midland unit that has the repeater channels already in so its an offset of +5 Any help here would be greatly appreciated That should be right, but you can always get rid of the R-CTCSS and see if the repeater hears you. That way you’ll hear the repeater response regardless of the tone. The other thing is don’t try to talk from one radio to the repeater to the other radio that’s just a few feet away. The second radio might be overwhelmed by the power of the first radio (called desense). stoutryan 1 Quote
0 Guest Posted October 24, 2024 Report Posted October 24, 2024 40 minutes ago, stoutryan said: I too am having issues setting up to a repeater. The data I have is the repeater freq is 462.700 RX and TX tone is 210.7 but once I input that data into two radios I cant seem to communicate and I know I am doing something wrong. What I have done is; created T-CTCSS of 210.7 And R-CTCSS of 210.7 Can anyone tell me if these settings are correct. I'm using a midland unit that has the repeater channels already in so its an offset of +5 Any help here would be greatly appreciated How far away are you from the repeater? Do you have line of sight to the repeater? What radio and antenna are you using. Have you heard the repeater in simplex before? Daily traffic or nets? Many many times people think they have the programming wrong, when I fact they just are not reaching the repeater. Quote
0 stoutryan Posted October 26, 2024 Report Posted October 26, 2024 I'm definitely hitting the repeater. I'm pretty close with line of sight and using a vehicle mounted higher output unit vs. a handheld. I did however have the second (handheld) radio pretty close when doing my testing so as Steve said I may be desense. Thank you both for your responses. more testing coming today since the rain seems like its going to be incessant Quote
0 stoutryan Posted October 26, 2024 Report Posted October 26, 2024 On 10/24/2024 at 2:57 PM, SteveShannon said: That should be right, but you can always get rid of the R-CTCSS and see if the repeater hears you. That way you’ll hear the repeater response regardless of the tone. The other thing is don’t try to talk from one radio to the repeater to the other radio that’s just a few feet away. The second radio might be overwhelmed by the power of the first radio (called desense). Steve, First off thank you for the response. I think this is where I may have a bit of confusion. If the repeater has RX and TX tones wouldn't removing the R-CTCSS mean that I would NOT be able to hear the response from the repeater since its sending a tone out with it? Quote
0 SteveShannon Posted October 26, 2024 Report Posted October 26, 2024 3 minutes ago, stoutryan said: Steve, First off thank you for the response. I think this is where I may have a bit of confusion. If the repeater has RX and TX tones wouldn't removing the R-CTCSS mean that I would NOT be able to hear the response from the repeater since its sending a tone out with it? No. If your radio is set without a receive tone it reproduces everything detected on that RF frequency. But if a tone is set then it must match. So by leaving the receive tone out you are able to hear everything on the repeater. stoutryan and WSFK665 2 Quote
0 stoutryan Posted October 26, 2024 Report Posted October 26, 2024 14 minutes ago, SteveShannon said: No. If your radio is set without a receive tone it reproduces everything detected on that RF frequency. But if a tone is set then it must match. So by leaving the receive tone out you are able to hear everything on the repeater. Thats definitely where my confusion was. Thank you! SteveShannon 1 Quote
0 stoutryan Posted October 26, 2024 Report Posted October 26, 2024 Does this methodology work the same for digital tones? Quote
0 SteveShannon Posted October 26, 2024 Report Posted October 26, 2024 Just now, stoutryan said: Does this methodology work the same for digital tones? Yes, exactly the same way. stoutryan 1 Quote
WRKS933
10 answers to this question
