WSEA699 Posted November 3, 2024 Report Posted November 3, 2024 Hi all! Putting together a comms bug out out bag and looking for some direction. I've already secured a Fara-J antenna and throw line. What coax would you recommend that is lightweight yet good quality? Looking for about 50 ft. Also any recommendations for sbiners. Thank you in advance! Quote
Guest Posted November 3, 2024 Report Posted November 3, 2024 I offer this resource: https://kv5r.com/ham-radio/coax-loss-calculator/ And I make a suggestion to set some sort of reminder or alarm to check the status of your batteries on a regular schedule. A ready bag is really a good idea but it's not a make and forget thing when batteries get involved. REI has so many 'beaners that your likely to get a shiny-hemorrhage in your brain should you go look Quote
Lscott Posted November 4, 2024 Report Posted November 4, 2024 20 hours ago, WSEA699 said: Hi all! Putting together a comms bug out out bag and looking for some direction. I've already secured a Fara-J antenna and throw line. What coax would you recommend that is lightweight yet good quality? Looking for about 50 ft. Also any recommendations for sbiners. Thank you in advance! I would recommend using RG-8X cable. It has far less loss than the typical RG-58 type and just slightly larger in diameter. You can use larger coax like LMR-400, less loss, but its much more bulky and heavy. But for a portable application I would assume you would like something small, light and easy to carry. All my portable radios I typically use BNC connectors. Those don't cause SWR problems and are low loss when using quality types. You can find adapters from just about any connector type to BNC. I have BNC adapters for all of my radios. I would use the minimum length of coax to get the job done. The link below is for a 25 foot RG-8X cable with male BNC connectors on the end. If you really need 50 feet then use two with a BNC barrel adapter. Otherwise the 25 foot one would likely be more than enough. https://www.dxengineering.com/parts/dxe-8xdb025 I use a portable mast system with about 25 to 30 feet of RG-58 cable. The higher loss on the cable helps to keep the SWR on the antenna down below 2:1. That's a trade off I made and I had the cable already. If a find a good buy on a RG-8X jumper cable I'll swap out the RG-58. https://forums.mygmrs.com/gallery/image/257-portable-mast-antenna-system/ WRXB215 1 Quote
WSEA699 Posted November 4, 2024 Author Report Posted November 4, 2024 Perfect, this is exactly what I was looking for. Thank you! Quote
