DB20g mobile radio as base and a midland mxta26 antenna on a midland nmo magnetic mount base. It is currently on a cookie sheet extended outside by the installed 16' coax on the mag base. I have been advised to get a lightning arrestor between the radio and the antenna cable connector. Ground the arrestor to a house ground. Then to drill a hole in the cookie sheet to allow the nmo base electrical connections to pass through the hole and then screw the antenna back onto the nmo mount. It was explained that this would give a ground plane to the antenna as the metal cookie sheet would contact the ground of the antenna and mounts coax ground and then to the ground wire on the lightning arrestor, to earth ground via the house grounding system. I hope I explained it adequately. This would turn the metal reflector (cookie sheet) into a real earth ground. What benefits will this provide in protection and reception?
Elbowmac
Thanks
Â
4 answers to this question
