Hello, I have this setup currently programmed for 467/462.5500 PL 127.3. Works great but it turns out i need to change the frequencies. I bought a single M1225LS to play with and it reads/programs fine. However, I put either one of the repeater radios on it and they both say the radio is not active, check cables etc. etc. Does something need to be done to activate them for programming? Thank you for any info provided.
mydog8em
I'm using the LS/CPS v3.0 if that helps.
2 answers to this question
