Comet SBB-1 NMO to Nagoya RB-700N NMO mount issue?
Just got both and was checking fitment and noticed the Comet SBB-1 NMO antenna on the Nagoya RB-700N NMO mount doesn't screw down all the way. Tested my CA-2X4SR NMO and same issue. Fits tight but has a little space so must be the mount.
So i took the mount apart and flipped the white spacer and now it almost mounts perfectly flush, like any NMO mount i have.
From this:
To this:
Which looks like this:
But this doesn't seem right ether....
Should i revert it back and get a rubber washer, or just use some Dielectric grease? Or is it good with the swap/switch?
1 answer to this question
