WSHG974 Posted March 8 Report Posted March 8 Im new to gmrs radio and have the Baofeng UV-5G PLUS and the manuel is pretty much useless. i want to set ip up to use a repeater in my area I have all the information and permission to use it as its a open repeater freq is 462.725mhz input tone dpl365 output tone 218.1 mz any help would be great ! Thanks in advance WSHG974 Quote
TDM827 Posted March 8 Report Posted March 8 I don't have a Baofeng, but there are tons of how to videos on YouTube on how to use them. I am sure you will get some great info here as well. Best of Luck. SteveShannon and WSHG974 2 Quote
OffRoaderX Posted March 8 Report Posted March 8 Select the correct repeater channel which in this case would be REPEATER Channel 22 Go into the menus and find the TX DPL/DTC setting and select 365 from the list Ignore the RX/Output tone for now as it is optional and you are already confused enough That's it - should take a total of about 20 seconds. I found this random video on Youtube that explains step by step exactly what you want to do using a UV-5GPlus: SteveShannon, WSHG974 and amaff 3 Quote
TDM827 Posted March 8 Report Posted March 8 50 minutes ago, OffRoaderX said: Select the correct repeater channel which in this case would be REPEATER Channel 22 - you may have to resort to reading the user-manual to see how it is listed/labeled for your radio. Go into the menus and find the TX DPL/DTC setting and select 365 from the list Ignore the RX/Output tone for now as it is optional and you are already confused enough That's it - should take a total of about 20 seconds. I found this random video on Youtube that explains step by step exactly what you want to do using a UV-5GPlus: WSHG974, If you already haven't figured it out OffroaderX,s youtube channel, "Not a Rubicon" is a good place to start learning if you are new to GMRS SteveShannon, WSHG974 and WRTC928 3 Quote
WSHG974 Posted March 8 Author Report Posted March 8 2 hours ago, TDM827 said: I don't have a Baofeng, but there are tons of how to videos on YouTube on how to use them. I am sure you will get some great info here as well. Best of Luck. Thank you for your help I have been watching some but nothing about the plus also would you know about the same question for a Radioddity GM-30 PLUS ? I have both and end up the same results with both Im pretty sure its me not getting something set right, SteveShannon 1 Quote
WSHG974 Posted March 8 Author Report Posted March 8 Thank you for your help I have been watching some but nothing about the plus also would you know about the same question for a Radioddity GM-30 PLUS ? I have both and end up the same results with both Im pretty sure its me not getting something set right, Quote
WSHG974 Posted March 8 Author Report Posted March 8 34 minutes ago, TDM827 said: WSHG974, If you already haven't figured it out OffroaderX,s youtube channel, "Not a Rubicon" is a good place to start learning if you are new to GMRS Thank you so much for your help !!!!!! SteveShannon 1 Quote
OffRoaderX Posted March 8 Report Posted March 8 1 minute ago, WSHG974 said: would you know about the same question for a Radioddity GM-30 PLUS ? The basic steps are exactly the same.. Also, you have to ensure that you are close enough to the repeater to actually activate/use it - just because you can hear it does not mean it can hear you. SteveShannon and WSHG974 2 Quote
WRUU653 Posted March 8 Report Posted March 8 1 hour ago, Socalgmrs said: Get a programming cable and use chirp. And then what? Radioddity GM-30 plus is not Chirp supported at this time. SteveShannon and WSHG974 1 1 Quote
TDM827 Posted March 9 Report Posted March 9 Are you using a programming cable or trying to program through the radio itself. For my Radioddity GS-5B both computer and blue tooth programing are pretty intuitive and easy to figure out. Not sure if the GM-30 is blue tooth capable, but they do offer programming cables. As OffRoaderX brought up. It sounds pretty basic, but is your repeater fairly close? Sometimes hitting a repeater from a handheld can be a challenge especially from inside your house. WSHG974 and SteveShannon 2 Quote
WSHG974 Posted March 9 Author Report Posted March 9 20 hours ago, TDM827 said: WSHG974, If you already haven't figured it out OffroaderX,s youtube channel, "Not a Rubicon" is a good place to start learning if you are new to GMRS Thank you so much for your help !!!!!! I ordered the programing cable will try it when it comes the repeater a pretty close to my location so I dont think that should be a problum I just dont know what menus to use for the inputs Im not the brightest crayon in the box yet Still learning and all the help I get is great ! Thank you to everyone WRUU653 1 Quote
SteveShannon Posted March 9 Report Posted March 9 44 minutes ago, WSHG974 said: Thank you so much for your help !!!!!! I ordered the programing cable will try it when it comes the repeater a pretty close to my location so I dont think that should be a problum I just dont know what menus to use for the inputs Im not the brightest crayon in the box yet Still learning and all the help I get is great ! Thank you to everyone Page 32 of the manual tells which menus to use to set the transmitting CTCSS or DCS. Menu 8 or 9, depending on which you need. WRUU653 and TDM827 2 Quote
WRTC928 Posted March 11 Report Posted March 11 On 3/8/2025 at 12:38 PM, TDM827 said: WSHG974, If you already haven't figured it out OffroaderX,s youtube channel, "Not a Rubicon" is a good place to start learning if you are new to GMRS It's not a good place to start if you're easily butthurt, however. WSHG974 1 Quote
TDM827 Posted March 12 Report Posted March 12 2 hours ago, WRTC928 said: It's not a good place to start if you're easily butthurt, however. LOL, I prefer to think of it as dry humor with some sarcasm added in to keep people from taking themselves to serious. WRTC928 and SteveShannon 2 Quote
WSHL996 Posted March 15 Report Posted March 15 On 3/8/2025 at 10:44 AM, WSHG974 said: Im new to gmrs radio and have the Baofeng UV-5G PLUS and the manuel is pretty much useless. i want to set ip up to use a repeater in my area I have all the information and permission to use it as its a open repeater freq is 462.725mhz input tone dpl365 output tone 218.1 mz any help would be great ! Thanks in advance WSHG974 Hi Channel 28 is preprogrammed for that frequency, just configure the following Input tone - menu item 12 (T-CTCSS) Output tone - menu item 10 (R-CTCSS) You may also do it via software Input tone - TX CTS Output tone - RX CTS SteveShannon 1 Quote
