I am very new to GMRS, Today I set up an RT97S GMRS repeater and programed in some squelch tones on repeater channel 15. I programed the repeater tone into all my other radios and began to test them. 1 of the 8 radios I tested was not working correctly.
The radio is a BTECH UV 25x4 mobile that I have set up as a portable base station. I can receive and transmit on all the GMRS channels just fine save for the repeater channels. This is what happens:
The UV 25 can receive calls thru the repeater channel just fine, when I transmit from the UV 25 to the rt97 I get the tail squelch indicating that I have connected to the repeater and then it just goes into this looping static buzz. When buzzing the radio shows that it is receiving at a low signal.
The sound will stop and the channel will reset if I change channels or if I key up the repeater channel from a different radio.
I got this static loop when testing with repeater and mobile in the same house as well as when I tested them 2 miles apart and got the same noise. If my TX and RX and + - .5000 offset is incorrect would I still be able to connect with the repeater? Any insight would be much appreciated!
WSHB586
15 answers to this question
