WRXL702 reacted to a post in a topic: I'm thinking about getting a Radioddity DB25-G GMRS Mobile Radio 25 watt.
SteveShannon reacted to a post in a topic: Need a 3D belt clip for my Baofeng! Any suggestions
The RT-3S is exactly the same radio as the TYT MD UV380 that I have. Just a different name plate. As such it’s a candidate for OpenUV380 (~OpenGD77)
WSEN940 reacted to a post in a topic: Is there lost connections thing here...
TNFrank reacted to a post in a topic: Radtel RT-4D is up and working.
Here's an excellent video I found showing how to set up a DMR radio. I was looking at the Retevis RT3S. It's 2M/70cm(so I can probably do MURS and GMRS too) and it's supposed to be 10 watts. The price isn't too Bad either.
WSJS332 joined the community
WRYW366 started following How is the Comet CA-2X4SR antenna?
If you want "CHEAP" but a good quality radio look at this one. It's a "Type-2" UHF radio with a band split of 400-470 MHz. The seller privately sent me a photo of the Kenwood tags without the other ones stuck on top of them, like you see in the AD, so I verified the FCC ID of K44475500. Covers all of the Ham band and you can use it in FM mode on GMRS too. https://www.ebay.com/itm/267383407451?_skw=kenwood+dmr+radios&itmmeta=01K4DNYSK8VG0D44XQ4VBAKFQ7&hash=item3e414b035b:g:cQMAAeSwTDpoercB&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1cjUvNiekyv67x3Pun95fxmvfQaGHlVZBC5MpGFZBOOrwa25XAEL2ZcbEvb%2BwGjTRgJBsaTqPa0fqAKfM6lXLrl2czT7iF3%2FxpqmSYRH8GTl7XnCJQFzr2z%2BjaYmlgJF6s5DohBVA8hAPSKODzBFKr1l9Ijbp0Y%2FgU43W1fFHDrY1Ooug1UHejG6jqwEly5qneA%2ByyjGxiD6BFvvDgJ91WUEASOVqdkoJwuDTv8Y6w69CQfPSw4OYHF4uBxY6tqs%2FdFT596uuYUzCMG3IcCfNMeZNiygMsW5cOBb%2F6LXoFh1Q%3D%3D|tkp%3ABk9SR-iZ-7WjZg&pfm=0 It's a Kenwood radio. For the price you can experiment with it. You'll likely have to get a KSC-35S charger base, typically used about $20 to $25, I have several in my collection. The Boafeng programming cable and speaker mic's that use the two-pin plug will work. I use a cheap Boafeng programming cable on my Kenwood radios all the time. Two main con's are no front panel programming and no display. But for DMR you're likely going to do all your programming on a computer anyway. I have the software and a sample code plug if you're interested. TK-D240V_D340U Brochure 1.pdf TK-D340K2_GMRS_Analog_DMR_Example.dat KPG-166D_v2.33.rar
My experience with Wine is it works sort of OK so long as the app isn't doing really weird stuff behind Window's back, like undocumented functions, or depending on bugs in various Window's functions always doing the same thing etc. BTW that's one of the biggest headaches with Wine, and the RealOS Project, is duplicating all the bugs in various parts of Windows so existing apps work as expected. It's another reason why later versions of Windows breaks old app's, Microsoft just didn't bother duplicating the older version's bugs in some cases.
All that being said the absolute high was 3.3 watts on digital mode. I'm looking at 3 other radios between $100 and $150 that claim 10 watts. even if they only output half of that it'll be better than the 3.3 watts I'm getting from this radio.
Destro replied to HamsterDancer's topic in General Discussion
More like Phyllis Diller. -
Remember DMR uses TDMA when working through a repeater in digital mode, Time Division Multiple Access, in other words the output is pulsing on and off approximately every 30 milliseconds. Your typical average responding power meter will likely read about 40 percent of a true FM radio output. So, a reading of 2.5 watts wouldn't be unusual. The 0.5 watt reading the meter might have caught the radio part way through a transmit pulse, which wouldn't surprise me with one of those electronic SWR/watt-meters types.
You CANNOT use a standard watt meter to verify power output on DMR (or any TDMA mode). It doesn't show up accurately because it pulses every 30ms for each timeslot. Also, if it's overloaded by surrounding RF, it will bonk. DMR (in a repeater scenario) sends a ping to the repeater, and if it doesn't "hear back" from the repeater after I think 3 attempts or so, it says out of range.
Destro reacted to an answer to a question: Counterpoise
I just did a power output test on the radio. The DMR Repeater I have programmed was giving .5W to 2.5W jumping around and not consistent. I think that's the main issue, not enough "azz" to hit the nearby repeaters that my analog radios(even the little UV-5r) can easily hit from my backyard. It's getting returned and I'll use the funds along with the money from the DM-1701 to buy a better radio. Also, WINE works pretty good on my Linux install. Like I've mentioned before, I run all the other CPS programs along with CHIRP NEXT in WINE without issues.
Destro replied to WSBX980's topic in Guest Forum
I do not believe so. -
WSJW569 joined the community
I downloaded the Radtel RT-4D CPS DMR programming software so I could look at your analoge codeplug as well as the Miklor sample codeplug… SO UGLY! And thats in Windoze on my Mac; I can’t imagine it in Linux!! Good luck! Have you driven closer the the repeater to see if your RT-4D works in DMR?
WSHG348 joined the community
WRYS709 replied to Andrei's topic in General Discussion
Some posters do not understand the two types of people on these types of forums: 1) Those that cannot do or are unwilling to do internet research and hence prefer to be spoon fed; and 2) Those that get personal achievement and gratification from doing research for others! ”I want my Maypo!” -
Programming Baofeng UV-5G Plus Repeater Help
WSJV402 replied to WRZX627's question in Technical Discussion
This worked for me for my Baofeng UV-5G Plus. Make sure you're on the correct COM port from the dropdown menu and select the Radioddity UV-5G Plus. -
WSJV402 joined the community
WSJX263 joined the community
WRHS218 reacted to a post in a topic: GMRS license covers my family? And etiquette for family chat?
WQQP429 joined the community
SteveShannon reacted to a post in a topic: GMRS license covers my family? And etiquette for family chat?
WRYW366 changed their profile photo
WRYW366 reacted to a post in a topic: You just got your GMRS license, now you want your own repeater?
W1DGL replied to HamsterDancer's topic in FCC Rules Discussion
OK, Fight nice, children (everyone). -
WSJX324 joined the community
Those are hard to tune. Patience Grasshopper. Keep trying.
Has anyone used the Midland or the Retevis repeaters?
WRHS218 replied to WSBX980's topic in General Discussion
I have used the RT97 and the RT97L. Both perform well. If you have the money and are set on getting this type of repeater I would go with the RT97L for the reason the Queen of ALL GMRS mentioned. In this case more power helps mitigate line loss. They are not 100% duty cycle machines but are good for what they are. The portability is a great selling point. YMMV -
daveyfig changed their profile photo
daveyfig joined the community
That never stopped eBay from allowing this crap on their site. When it comes to CCTV equipment Hikvision was FCC banned and eBay was flooded with that garbage. I don't see any of this significantly changing for the better on eBay or Amazon.
When I use my HT for GMRS, I make sure I have an aluminum beer can in my other hand for counterpoise. Obviously, you have to empty it till you find that perfect resonance sweet spot. Sometimes it takes multiple tries to get it right.
For optimal performance I highly suggest using Bosch Platinum spark plugs with the gap at 0.038" for the HF bands. Spark gap transmitters can be fun. Brings back the good old days of radio.
I downloaded a codeplug from Miklor for the RT-4D and compared it to my codeplug. I made some adjustments to my codeplug and I still can't reach the repeater. When I keyed the HT next to my desktop computer I heard something like it WAS sending out a signal but I just don't think these little radios are powerful enough to make the 16 miles to the repeater in digital. In Analog yes, they reach it. I guess I need to do a power test on the radio and compare analog to digital and that would also confirm that a signal was getting out in digital mode.
I did find something else that looks like a mistake. In the Notes for the repeater it says the ID is 313402, but in the actual live data down below it says it is 310402 and that's a live link to RadioID that looks correct. I think the Notes section in RepeaterBook is incorrect where it says 313402. All of the AZ DMR IDs start with 3104... 313402 is a repeater in New Jersey if you look it up: https://radioid.net/database/view/dmr/repeater?id=313402 This is the one in AZ: https://radioid.net/database/view/dmr/repeater?id=310402 I've gotta go to bed before I turn into a pumpkin.
jhayesflight joined the community
I think so. Of course this is a radio I haven't programmed before, so it's entirely possible I'm missing something, but for 3104 you have the correct Time Slot. For the repeater you have the correct Color Code and for the repeater you have the right frequency. I don't have the repeater DMR IDs programmed in any of my code plugs except maybe in a field in OpenGD77. In all of them I use the Talk Group ID. Like I said, it's counter-intuitive. You're connecting through the repeater, not to it. You’re telling the repeater which TG you want.
Ok, I'll give that a try. It does seem in the CPS that the repeater ID should go in that box but I'll try the talkgroup ID and see if it works. Did everything else look ok other than that.
OffRoaderX replied to WSBX980's topic in General Discussion
You sir, are a true pillar of your community !
