LeoG started following Retevis RT97L portable repeater -- first impressions
LeoG replied to WRTC928's topic in Equipment Reviews
Jaay reacted to an answer to a question: Seeking Larsen NMO2/70B experience
Jaay reacted to a post in a topic: New Install - Dual Astro XTL5000 - VHF / UHF, 110w
Jaay commented on Lscott's gallery image in Members Albums Category
Does Anyone Remember the tricks that were used by Federal or Tactical law enforcement vehicles in the late 60's or Early 70's ?? You wouldn't recognize their cars at all ... Unless you got Right behind them ! The Antennas were Quarterwave antennas, usually Vhf and mounted INSIDE on the rear package shelf of the Rear window ! Under the carpet on that shelf was STEEL and made a Great ground plane ! -
WRHS218 reacted to a post in a topic: GMRS for LA Riots.
WRHS218 reacted to a post in a topic: Retevis RT97L portable repeater -- first impressions
WRYZ926 reacted to a post in a topic: Retevis RT97L portable repeater -- first impressions
SteveShannon replied to WRTC928's topic in Equipment Reviews
WRYZ926 replied to WRTC928's topic in Equipment Reviews
I still have a ways to go before I reach @SteveShannon status -
OffRoaderX replied to WRTC928's topic in Equipment Reviews
less than 10 paragraphs and no big technical-sounding words, so you did good! -
You are seeing loss from the coax and/or the antenna. Using quality coax and a good antenna with some gain will help overcome any loss. A dummy load will show a perfect match of 50 ohms, there won't be any loss with the dummy load. @OffRoaderX was that a simple response? I know I have a ways to go to catch up to @SteveShannon -
WRQB826 started following Radio gear and Radio Etiuette
WRQB826 joined the community
WRQW483 changed their profile photo
Vekta changed their profile photo
Vekta joined the community
WSHH887 started following Could FM CB supplant FRS?
Most folks seem to have no idea what GMRS is. Anytime someone asks about my antenna on my truck the think it's CB.
WSIK532 commented on Lscott's gallery image in Members Albums Category
BETWEENtwoWORLDZ started following Luish19779
BETWEENtwoWORLDZ started following Joe355
BETWEENtwoWORLDZ started following capy
WRXU573 joined the community
TerryS joined the community
WSHX597 joined the community
AlexisGMRS replied to marcspaz's topic in General Discussion
With the XTL series you can two control head.. you have to obtain a special cable and program it properly. The option is designed for special applications like fire trucks -
BETWEENtwoWORLDZ started following Melvin272
Only if you remove the battery.
Because reasons... That's why its always best to measure with a dummy-load.. A radio-dork will come along momentarily to write a 10-paragraph explanation that makes them look really smart, but basically says the same thing. -
WRTC928 replied to WRTC928's topic in Equipment Reviews
I checked it with a dummy load and got a consistent 18 watts, which is about what I would expect, given the loss due to the duplexer. I'm puzzled about why I get different power readings with different antennas, though. If someone can explain it, please do. I'm still learning. -
Sorry, no. I do what @LeoG recommended. It's surprisingly capable for a $25 radio, but it's still a $25 radio. You can't expect everything.
So, if I turn my phone off at my home, it won't be detectable again until I turn it back on?
True, but I was actually thinking of vehicle-mounted radios. When I think of CB, I still think of mobile units. Probably because I'm old.
i had similar experience with a cowel mounted Midland antenna on my JK, which i dearly miss
WSHW967 joined the community
This is correct.. The antenna on both my Jeeps is mounted on the rear tailgate where all of the "experts" have decreed it "will not work!!!1" because the lack of a perfect ground plane.. It is true the antennas would likely perform better with a good ground plane but both antennas have an SWR of around 2, and I regularly talk with people dozens of miles away, and was able to hit a repeater 93 miles away.
What would generate a Morse code ident on channel 6?
Jaay replied to WSCB609's question in Technical Discussion
DO I ?? Yesssireee Randy, N9ZAS and WSCL633 ! -
The need for a ground plane are overrated. Here's a pic of the NMO2/70B on my new 2025 Goldwing, which is mounted in the right rear. As you can see there's no ground plane and the performance is equal to the NMO2/70B on the roof of my truck. You couldn't tell the difference in a double-blind test. I can hold a repeater in Baltimore all the way to down to the Patuxent river bridge in Southern Maryland with both vehicles. If there's an antenna any better than the Larsen I haven't found it.
OffRoaderX replied to WSCB609's question in Technical Discussion
When a radio-dork says "CW", 99.9999999999999998% of the time, he is talking about, referring to, or eluding to Morse-Code... Do you even have a license bro? -
I use the 2X4 with no ground plane and it's Consistently 1.2 -1.4.1 on 2m/ Murs/70cm/ and Gmrs and even covers 222mhz. @1.5.1 swr although it's not really intended for that band. The previous antennas are no ground plane, but seem to perform better with one.
Thank you, I'll check them out. I've looked into the SBB-5 but couldn't tell if it's NGP or not. Its product sheet says something like non-radial, but the CA2X4SR says the same on its product sheet, and definitely needs a ground plane.
