D793 joined the community
That would be a tragic waste
amaff reacted to a post in a topic: Dear Mr President Trump...
grindstone joined the community
Kill and Stun are off in OD Master too. Interesting......
Just looked. Kill and Stun are turned off in the CPS, not sure about the OD Master.
RoadApple reacted to a post in a topic: Roger Beep
Weird. Turned on the H3 and it was in Stun/Kill mode, no access. Thought I'd have to talk with Luxi again. Turns out if you use the USB port and their CPS you just reprogram the radio and you're all set. I have lots of AM stations in my radio for the airport and the CPS won't program those. But I also use OD Master and it has all those programmed in it so just re-reprogrammed it and it's all back to normal. Took about 1 minute. No idea what set off the kill mode though.
Bobuff977 reacted to a post in a topic: New Repeater Channels for GMRS in 2024
Pretty much. Except GMRS can do repeaters.
Theoretically yes, but in practice the opposite has often proven to be the result. What happened was that FM dropped out at essentially the same distance that AM became unintelligible. AM broke squelch farther away, but was completely unreadable at max distance. If I recall FM was full readable where AM was 50/50.
JasonRaborn1 joined the community
HolgerG joined the community
Neat! Probably a bit of both, plus a dash of luck.
I have traveled and spent time camping all over the place. The only place i have encountered 70CM tropospheric ducting is right here in the Indian Wells Valley or the foot of the Sierras. And the traffic i was picking up was coming form Southern California, just a mere 140miles south. Although i tried a couple times, i never was able to make a contact with someone 'ducting' in but their conversions were coming in like there were sitting next to me.
WSIF678 joined the community
I do tropospheric ducting with GMRS. Just takes the right conditions. And I've never really gotten huge distances. Just impossible connections. Where I am and where I connected has a huge mountain in between that makes it impossible to have any sense of LOS. It's only about 70 miles and it only happens in the summer. And it's only happened once this summer and I'm not sure if it's conditions or from me going from a 7.2dBi to a 9.8dBi gain antenna. There was one night were I was able to connect and talk with several people with my HT and they said it was R9. Very unlikely unless you live in SoCal....
WSIN223 joined the community
IIRC both are primarily line of sight so performance should be roughly the same, especially with HTs. You can take advantage of troposheric ducting with 11m/CB for the occasional long distance connection (whereas UHF just punches through the atmosphere) but you can't rely on that for regular communications.
capei started following Wouxun KG-1000G tips and tricks thread
just don't spill it on ya
you have a point.. my shirt was looking out for for me
and you didn't spill coffee on your shirt reading it.. you're lucky
two violators don't make a right
amaff started following GMRS Trave Frequency?
Hey just like GMRS!
Uh... unless I'm mistaken this is not correct. AM CB will talks more fars than FM, no? As to @LeoG's question as to what is the difference? FM is a little cleaner, sounds a little warmer. But nobody, en masse, is talking on it so unless it's you and someone else you plan to have comms with, there's no need to get one. I have one. It stays on AM band 24/7.
I'm really wrestling with what, in this thread, is the most odd and simultaneously impressive. The fact that the OP has been a member of this site for 4 years and has only just now chosen to post or the fact that his first post is literally a letter to POTUS. I applaud the energy you expended on what is almost certainly a wasted effort.
We had someone doing that on our 2m and GMRS repeaters a few months back. The person would play sirens and a police scanner. What made it worse is the person did it during our nets. Saying anything just made it worse. So we just started to ignore the ID10T and he stopped after a bit. We also had a drunk that we sent a certified letter to stating he is no longer welcomed on our repeater. He stopped after receiving the letter. We still don't know if he was the one playing the sirens and police scanner over the repeaters.
Hopefully you didn't get any coffee on your keyboard and monitor or phone.
One of the local linked repeaters near me has been in almost constant chaos the last few days from somebody playing music on the repeater/network. Don't know what is worse - the person causing the interference or the folks wining about it but it's a fun battle to listen to.
Donny - " Wait, didn't I appoint someone to the FCC ?
President's agenda today: Zoom call with Putin Zoom call with Zalenski Status update on painting the fence black Hurricane hitting the eastern seaboard Tanning spray Touch up the quaffe Redistrict Texas and California voting. Say something to offend the vocal minority. (800 other things) (200 more things) Listen to an update on what letters to the president rose to the level of making it into the report (he's on the treadmill at the same time though) This letter didn't make honorable mention
He's our boy.
and sending a letter to the President? Talk about going 'over heads'
Damit... I need to change my shirt.. I spilt coffee all over my fresh clean shirt.. Damit... To early for this
