  2. LOL. Dear Sir, your contributions to this site more than make up for any beer deficit. Please consider the accounts balanced.
  3. Agreed. I have mine hooked up to a DB-25G, but I've come to the same conclusion: Nice, cost-effective way to do GMRS. Simple, no holes to drill and highly portable (I move it inside atop a pizza pan when not in one of several vehicles). I'm a lightweight user and you are hard-core, but we both agree that the combo is a lot of GMRS for $150.
  4. Two 25 ft lengths, sorry forgot to add that part.
  5. I agree, so ive decided to just replace it with two length of RG213/U that should be sufficient I think.
  6. Me too and I still owe you a beer!
  7. I still don’t know what the length is, but rg213 still sucks for uhf.
  8. The coax is less than six months old at this point, yes yhe connectors could be the issue. I am looking at just replacing it with two pre-made lengths of RG 213/U cable.
  9. You don’t mention the lengths of your RG-58, but for UHF almost any length is too much, but lossy cable like RG-58 will always make your SWR appear artificially low because less forward power reaches the antenna than passes through the meter so there’s less power to reflect AND much less reflected power reaches the SWR meter after reflecting from the antenna. So although the losses in RG58 is a problem, it’s not the cause of your SWR reading higher. Second, although a short or an open can be detected by a multimeter, the effect of RF frequencies is completely different. Yes, detecting a short would be reason to discard a connector or a cable, but resistive losses, the 002 (I assume that’s 2 millions?) that you measured are nothing to worry about. Without a dummy load and antenna/coax analyzer or nanonva your best option is to simply remove a piece at a time, replacing it with a known good component.
  10. My 4 non transmitting tdh3’s all receive exceptionally well. They work great on receive. FWIW.
  11. Going to agree with Steve on this. Given everything other reply from OP it seems as though either the connector didn't go as well as thought (the multimeter test doesn't show as much as a VNA does) or something is wrong with the coax. Age of the coax? I may have missed this. How long has it been outside? Have you sealed the connectors against the weather? Almost sounds like the connectors are the source, but that is just from antenna building experience as when all else fails, it's almost always the connector.
  12. The radios are sensitive enough to hear the local oscillator or using the wire to the antenna as an antenna. I'm betting all these units showing up like this have a wire not connected to the center pin of the antenna. I have a couple and eventually I will take one apart to see if it's as simple as a bad solder joint. Which is what I expect.
  13. At least it's not water infected like mine got. I went from a 1.15 to a 2.08 and reception and transmission were affected substantially. Under 26ºF everything went good. As soon as it went over freezing it went bad. After the cold weather went away so did my reception and transmission. Replaced the bad antenna and coax section got swapped over to Heliax. Great stuff. Good luck with solving your issue. It's never fun when it happens and you can't figure out why.
  14. Today
  15. I love this bar.
  16. I did test the continuity of both the connections as well as cable,I did suspect a short. As I said I had a reading of 002 which shows the smallest bit of resistance. If need be ill replace the rg58 with two pre-made lengths ,maybe upgrade from the rg58. My current swr is now 2.3
  17. So I retried removing the arrestor and retesting. I went down to swr 2 , I then reattached the arrestor and and re tested with an swr of 2.3
  18. I’d start with the rg58 it may have gone bad internally when you messed with it.
  19. If the SWR doesn’t go back down when you remove the arrester, the problem isn’t the arrester. You either have a bad connector, cable, or antenna. Swap each piece out individually until you isolate the problem.
  20. No,sorry I forgot to add that in, I removed the arrestor and added a coupler,nothing changed. I could try it again just to be through.
  21. If you take the lightning arrester out does your SWR go back down?
  22. I have tried everything from firmware, to reset, to ptt+Star+power on reset, to using cps, and chirp, and copying the files from my only working tdh3. Nothing fixed my transmit issue. The dead or no output radios will work a few hundred feet apart but they all register no wattage on my meter. Learn from me!!! Don’t waste your time on trying to get them to work. You won’t. I’ve wasted HOURS messing with mine and still no joy.
  23. I have a question, the swr on my base radio has changed after installing a UHF lighting arrestor in line on my antenna cable (rg58) at the antenna mast. It has gone from 1.5 to 2.4. I double checked my fittings ( installed pl259 solder/crimp connectors ) for continuity with my multi meter which gave me a reading of 002 . A very slight bit of resistance . I did the same check on both sections of cable with the same readings. The arrestor is designed for uhf, it's the gas cartridge type ,I have a ground wire ran from it to a common ground stake where several other antenna are grounded. I know an swr of 2.4 isn't the end of the world,but I'm at a loss as to the increase.
  24. And step away from the keyboard
  25. @M5Fan - any luck getting to that repeater? Did any of the ideas and suggestions give you any answers to what you might need to do?
  26. I'd try the mag mount in the attic first, but hitting that distance with a handheld in an urban area is going to be a challenge.
