  2. Today
  3. yup, its a good idea to auto identify your repeater station, especially if it is an open repeater. At the end of the day, Its operation is the owners responsibility. Also a good idea to set up for remote access to disable if needed.. I have never had to remote shut down mine but a nearby friend has a few times due to jamming. Another thing he does, that i don't, i probly should, if he is away from montering range he shuts his down.. His is set up for continuous 15 minute ID intervals. I dont like that, i think it is silly, so i set mine for ID on Busy only on 15 min intervals. It's a personal preference thing. He does it so people can find and identity that particular repeate which has a very very wide operational range.
  4. This makes me cringe. I worked in 12v industry for so many years and running anything beyond a phone charge out of the cig plug is questionable at best. Even Garmin's and radar detectors we would 100% of the time hardwire them into better circuits then the lighter plug. Remember your voltage effects your power output as well. My kg1000g+ puts out the full 50 at 14.4 @ 9.7 amps if i pump up the voltage to 15 it puts out 51ish watts at 8amps. Most vehicles while running will have around 13.8v to 14.4v.
  5. Yesterday
  6. Send Repeater ID a email they are very nice & helpful. This is what they made for me for mine. Bushnell_pause_added.mp3
  7. Yes you should not have any issues with RT Systems.
  8. Thanks for the reply. I use chirp and planning on changing the frequencies to use GMRS. Does the RT package offer the programming to do the same?
  9. this guy fibured it out
  10. GMRS is actually not bad until you get into the bigger cities..Then it seem's 'Game off' time
  11. Stateside things were tight and we didn't have kids yet. But when I was stationed in Spain we even managed to save some. The exchange rate was very favorable, unlike Italy, England and especially Germany. Honestly, that was my best duty station. All the fun and no one was shooting at us. Although, it did come darned close a few times. The ETA really didn't like American servicemen.
  12. The RT Systems softwares is not the same as the free software that you can download. I find the RT Systems software works better.
  13. I was making $625 a month when I first enlisted. I did go in as an E-2 though. I forget what jump pay was at that time but it was nice to have the extra money per month. Everyone that is E-5 and below and also married are usually always broke. At least that was how it was when I was in.
  14. I'll be purchasing the KG UV980P at "Buy Two Way Radios". I tried calling them, but they are closed. They offer a Free software download, but they also Sell the "RT Systems Programming Software and Cable For Wouxun KG-UV980P." I'm wondering if the software that's for sale (with the programing cable) is the same as the Free download. Does anyone know??? It doesn't make sense to purchase the software if it's the same... and the cable is only $16 bucks. Thanks
  15. Goo heavens, you made that much. I remember my first months take home pay was &147.00. But by '75 I was an E-5, married and getting sep rats and quarters.
  16. Except I then see it descending into to mess that CB is today.
  17. Your repeater isn’t required to ID if and only if the only people who use it are people you have authorized to use your call sign and they identify correctly. If anyone with a different call sign uses your repeater, the repeater must be IDed. You can certainly do that manually and it definitely doesn’t have to be Morse code, but the repeater must be identified. Morse just happens to be built in for some controllers. Personally I prefer English language IDs also.
  18. FCC Part 95.1751 (c): (c) Any GMRS repeater station is not required to transmit station identification if: (1) It retransmits only communications from GMRS stations operating under authority of the individual license under which it operates; and, (2) The GMRS stations whose communications are retransmitted are properly identified in accordance with this section. In Other Words, Your Repeater Station Users Are Required To ID, Along With Your Licensed Group Users As Well. Really No Need For Your Repeater Station To Auto CWID - Unless You Just Think It's Cool..... Unfortunately, This Can Cause Issues If You As The Licensee, Do Not ID On Your Station, Due To Auto CWID - Others May Follow Suit Thinking The Repeater ID Is Satisfying Their Repeater Station ID User Requirements. I Do Not Use Station CWID On My Repeaters For Just That Reason.
  19. Welcome to the forum. Does the RICK controller have an ID function? The ID can be your call sign in Morse code if it’s easier. The RepeaterID breakout board can be used with the RepeaterID for use with “surplus repeaters” according to the website.
  20. Devin, that is not a very helpful answer is it?
  21. Why? You don’t need to, and it’s pretty annoying having to hear one every 15min.
  22. I have a GMRS repeater using two Motorola CDM 750 radios with a Motorola RICK controller. How can I add a station ID? I saw a simple add on device from RepeaterID.com but it seems it is mainly for the Retevis repeaters. Is there some way to adapt it to my repeater? Thanks WSAU511
  23. Do they just... burst at 50?
  24. When you're making $505 a month defending democracy, you go cheap! Except for my golf clubs back then...
  25. Fun fact: no one on the RR forums has an anus.
  26. Okay, 55 years ago it was $20, then it was reduced to $4 (that was when I first considered getting a license because $20 was way too much!) The point is that the government has no problem reducing the cost of the license, even to zero.
  27. I don't remember paying when i obtained mine in around 74.. If I remember correctly, i went too the local post office on base, filled out a form, name address, birthday etc. checked two boxes agreeing to abide by rules and sent it with a prepaid stamped postage card. About 30 days later l got my call sign in the mail. For the life of me, i can't remember that call sign.. Probably cause i never used it .. Back in that day, I don't think i would have wasted $20 for a license, considering that could have filled the tank in my 70 SS Chevelle 5 times.
  28. Kraco CB's were the equivalent of GMRS CCR's today. They were the cheapest POS radio's you could buy.
