  2. I need to sand and paint the base of my UT-72. But it's still working just fine.
  3. What radio are you using? If I understand correctly, you're in Death Valley or somewhere around there? Your geography is more favorable to radio waves than what most of us have. I can't get a hundred miles here even with my 63" antenna and 50 watt radio. But for my normal shopping trips, the little UT-72 works just fine.
  4. Thx, up until the last statement. That’s productive.
  5. Today
  6. No, that wont solve anything. Follow these steps, EXACTLY: Confirm that the repeater is up/active/turned on Confirm that you have the correct channel & TX/Transmit tone Ignore the RX(Transmit) tone and REMOVE it from both radios Confirm that you are correctly saving/writing your changes to the radio by looking/confirming the changes ON the the radio itself Get close enough to the repeater that you can SEE it Get your two test radios at least 50 feet apart and test If after all that, its still not working, then using GMRS radios/repeaters may not be for you.
  7. I hear nothing; no kerchunk Have asked for radio checks - dead air I do have a Yaesu with MARS mod that I can listen / Tx from on GMRS as well. What process could I follow to see if it's setup to the repeater correctly or not? Set the KG-935G+ on RPTR channel 16R (467.5750) and other on 16 (462.5750) ... I've tried this and also get nothing on the Rx unit. Have RT Systems software for all units. Maybe I need to call them? Thanks for the help, all. Sorry to bother with such an elementary question.
  8. While many antennas are better the little 72 it is light years better than a salt shaker and for the money and simplicity it can’t be beat. One of my trucks still has one and it does 100miles simplex from an 20w mobile unit each and every day 7 days a week 10hrs a day with zero issues. It’s good in that for around $150 total you can get a really nice 20w water proof radio and antenna with coax that will work hard every day and tx over 100miles. Many people spend closer to $1000 and dont get any better, clearer, further signal.
  9. Really, my point was that an antenna that does what you want is a "good" antenna. I see a lot of comments about how the UT-72 and UT-72G aren't very good antennas or even are "crap" because other antennas can be heard much further. That may be true -- I haven't tested it -- but the 72 and 72G have served perfectly well for what I've done. If I can't get the signal out with a UT-72, I can't get it out with any other 1/4 wave antenna either. Obviously, if I were offroad rather than in an urban/semi-rural setting, my results might be different. Today I was able to get a response from someone on a GMRS repeater 59 air miles away in my truck, but that antenna is 63" tall. You never get something for nothing.
  10. The 712efc is rated at 112mph. I'd be surprised if it could handle that. My SWR is between 1:1 and 1.01:1 across the entire band, including 467mhz repeater channels. I was amazed. Best I got with my other antenna was 1.15:1 at the optimum frequency.
  11. The few Tram antennas I have used or setup for others were all easy to tune. And the included instructions are good. I do use a Comet CA-712EFC and it has been a good antenna that has survived several storms with 50MPH + winds without issue.
  12. Yesterday
  13. I stand corrected. You are right.
  14. Your attic antenna set up is almost exactly the same as mine. Ours is in our third story attic. I intended on replacing it with an external. But after doing some testing and realizing our topography meant an external antenna was not going to give us much benefit, I just stayed with the Midland / Pizza sheet set up. Low tech for sure, but it does exactly what we need it to do.
  15. Which is not only very simple, but the antenna is very forgiving, so it has a wide margin of error.
  16. Two thumbs up! The Red Engineering (RE) Simplex Repeater (SRPT-03) has been discussed in another post. This review is about the new piece of equipment by Red Engineering. Thay have taken a SRPT-03 with all the connectors and placed it inside a polycarbonate waterproof case with a custom made precision-molded ABS insert and foam liner along with a waterproof SNA connector for connecting an external antenna. This is somewhat similar to what RE showed on their website with the original simplex repeater where they put everything inside a Pelican M40 Micro Case. It required that the end-user drill and install a bulkhead SMA fitting for the antenna and any foam insert they wanted. The primary issue with this setup was the size of the M40 case required that the Baofeng UV5 use the small 1,800 mAh battery which really can't go a full 2 day period. The FieldLink Edge uses an Evergreen 56 Waterproof Dry Box Protective Case which allows for the use of the twice as large 3,600 mAh battery with USB connector for charging. The reason for buying a premade case from RE is that the simplex audio and antenna connectors are sized perfectly for the case and both the radio and simplex repeater fit tight and snug into the insert. It even has a velcro strap to hold the radio to the insert. It comes with a right angle SMA connector for the outside antenna which mandates that the case be in the horizontal position. I simply replaced that with a male to male SMA connector so I can put the case up a tree in the vertical position. I'm also getting a male SMA to BNC connector to make the use of the outside antenna easier. Unlike the M40 case this one easily accepts a small carbineer and or small dia. rope to the case. You can also buy an additional mount so the case can be secured to a wall, antenna mount or whatever and be removable. The case is not really made to accept usb c power (not enough room). If that is your requirement then it might be better to get something like a Pelican 1150 and make all the connections yourself. This case is for someone who wants a well-made, ready to go waterproof case where all they bring is something like a Baofeng BF F8HP and hook it up to use over a two day period. Just remember to push the little micro switch next to the right of the USB-c connector to initiate the repeater.
  17. for an all around basic and fair cost base antenna, It's gong to be hard to beat a Tram 1486. The trick is to tune them correctly.
  18. Confirming: You hear them but they don't hear you, and you don't hear the kerchunk when you key up the repeater? How are you verifying they can't hear you? Is it by asking for a radio check while you know people are active? Or are you listening for the kerchunk on the radio you transmitted with? Or do you have two radios in close proximity, one to transmit and one to listen? Different troubleshooting tactics apply to each.
  19. If you are in an urban area with a lot buildings between you and the repeater (or each trees), or indoors, and the repeater is not up pretty high.. yeah you could have trouble getting that far to it. A better antenna will for sure help, getting it up higher and in a clear area with line of sight will help. as mentioned above you mgiht be able to hide the antenna in an attic space (test it with a temporary setup first) ... and it would be good as mentioned above if you go physically closer to the repeater to a better location and just confirm that your radio is setup correctly to access it.
  20. You all are giving me much to think about. Lots of good information. Thank you! I've been slowly trying to learn about DBI. It's a newer term, at least for me. I've always understood of DB of gain was compared to a dipole. But I guess DBI is a little different. Kinda sounds like antenna manufacturers are cooking the books to make their numbers look better. The comet CA-712efc is the antenna I'm currently looking at. It seems to have the best performance within my budget. I admit, the repeater is an inexpensive retevis. I was never impressed from day one, but come to find out the antenna that came with it was damaged from the factory. I've since repaired it and upgraded the coax. It's made a huge difference. I'm trying to squeeze as much performance out of it that I can. I'm upgrading here and there as the funds become available. I'm also learning what I can about antenna gain. I've come to understand more about the higher gain antennas having a flatter radiation pattern as others have mentioned here. I don't think I have enough height for that to be a problem. I'm in flat, flat kansas. I only have trees to contend with. I understand if it were a mountainous region, a lower gain antenna would help radiate upwards and downwards depending on the elevation of the antenna to the surrounding terrain. These are all things I've been piecing together in what little time I have to devote to the hobby, I'm sure you parents will understand. Again, thanks for all your advise.
  21. I feel like I am crazy.. and I only have three radios. Thanks for making me feel better about myself.
  22. Maybe some people don't like the UT-72 because it's not tuned for GMRS like the UT-72G. I use the UT-72G because it was cheap and it works better than an antenna inside my vehicle.
  23. Yea you might just be too far for your set up. Have you driven closer to the repeaters to test? I’d stear very clear of j poles. Yuck. Do you have an attic? If not even a mag mount on a pizza sheet near a window will help a bunch. A base station would be best for more watts since you can’t get a really good antenna up high. some people will get upset about this next part but….a move to freedom out of the commie hoa might be a good choice as well.
  24. Using KG-935G Plus on 5W repeater channels with correct tone and can't seem to reach two closest repeaters - one, 11-14 miles away, the second 18-21 miles away in Texas (flat but congested in N Dallas areas). I'm assuming my antenna (stock) is not helping and I need an extendable J-pole and antenna of some sort. Not wanting exterior antenna (HOA and wife forbids); something I can put up and take down in my home office easily. Advice? Thanks
  25. The main reason I operate tones on the RX is noise. There is a lot of DMR and other digital noise in my area that is beyond annoying. It interferes with medium to strong signals by either degrading the voice or overriding it. Tones don't help when the interference is active while someone is talking. But I would be insane by now if I had to listen to all that crap.
  26. I leave mine on all day and only have a 2 mile trip to and from work. The draw for receiving is pretty small and more so if you have your lighting on the radio extinguish after 30 seconds after activity. When it's the dead of winter and temps are way below freezing I'm more mindful of the battery. But in the warm periods I don't think twice about it.
  27. keep trying, they'll get it back in stock
