WRVV907
WRVV907's Achievements
  1. Will the kg uv9px pick up p25 broadcasts
  2. I have a wouxun kg-935g that works "OK" with its stock antenna from my home. I'd like to know it there are replacement antennas that wouldn't be much bigger, (could even be smaller), that would be more sensative for bringing in more?
  3. I was asked by my seller to factory reset my radio. If I do this, will I loose the channels that came pre-programmed from the factory? Also, when I'm trying to transmit, should the ctcss be on or off?
  4. Hi, i have a wouxun kg-935g.i recieved permission from a repeater owner to use his repeater that I found on radio reference. Com. Problem is, no tones match the tones in the wouxon software I'm using. I then tried chirp and ran into the same issue. They are posting numbers in DPL & DL while the numbers are suppose to be in CTCSS. Is there a convertion that I should know about or is it just OK to email the owner for him to give me the tone codes? Blthanks.
