Suggestion #1: Talking on a repeater with nobody listening?
Answer: In trying to explain the problem, I think I made my post more confusing than need be. The second radio I am using is the designated listening radio, to ensure there is a radio listening on that repeater that could pick up my radio check request.
Suggestion #2: Set one channel with both RX tone and TX tone to 141.3. Report back with your findings. Also, maybe no one is listening.
Answer: I setup a channel on both radios with frequency 462.70000 and a RX tone of 141.3 and a TX tone of 141.3 which gives me the kerchunk on the transmitting radio when I release the PTT button, and then a kerchunk is received on the designated receiving radio a second or two later without hearing my verbal communication. My request for a radio check is not heard on the second radio.
Suggettion #3: Try turning off the RX tone...make it no tone required. Then see if you hear the test. The repeater may not be passing the 141.3 tone. And the repeater may be malfunctioning.
It almost sounds like a Digipeater. Similar to a regular repeater, but it records your messages, then re-transmits it on the same frequency.
Just a guess.
Where is this repeater you're referencing?
Answer: I turned off the RX tone and set it to no tone on both the transmitting and receiving radio. I still had the same outcome where you get the kerchunk with a static sound on both the transmitting radio and the receiving radio. The repeater is in Wooster, Ohio. On MyGMRS.com it is identified as Wooster 700
Suggestion #4: What radio are you using, and do you have the repeater in a repeater memory slot? You transmit to the repeater on 467 and receive from the repeater on 462.
Answer: I am using two Wouxun kg-935G radios.
If by memory slot, you mean programmed as a channel in the radio, then yes I do.
Correct. The transmit is 467 and receive is 462 (Offset of 5)
Suggestion #5: You can't have the radios right next to each other, distance from the transmitting radio overpowering the receiver. Try to get 10 yards or more between the radios.
Answer: I separated the radios by about a 1/10 mile and I still get the same scenario.
