I'm afraid that's not the same model. The GM-15 PRO and GMRS-PRO are different units. From what I read online, the Baofang GM-15 Pro is just a rebranded Radioddity GM-30 (or vice versa)?
And yes, I'm referring to voice/audio transmissions only.
Simplex works between the transceivers on GMRS channel 21 (462.7000 MHz). Tests worked today at a range of 2.3 miles before signal degraded due to hills and losing line of sight.
Based on the recommendations above, I tried removing the RX CTCSS tone. Here's the configuration for the radios:
Radios A and B are both set to "RPT-7" in channel mode. Per the documentation, this preprogrammed channel transmits on 467.700 MHz and receives on 462.7000 MHz.
The repeater in question is this one.
Both radios have TX CTCSS tone set to 88.5 Hz and no RX CTCSS tone.
Here is what I found when requesting a radio check:
Radio A: hold key, "WRXM214 requesting a radio check. Over." Let up key.
Both Radio A and Radio B receive a short static noise roughly 1 sec after I let up key on Radio A.
Third party replies to radio check and confirms their location is 6 miles away, well out of simplex range. My signal is weak according to them, but I'm indoors and using a short antenna at the time. I hear the reply on both Radio A and Radio B.
I then try transmitting another reply to the same third party from Radio B. Same behavior on Radio A, it does not play the audio transmission from Radio B but plays the reply from the third party 6 miles away.
I change Radio A to CH-21 (TX and RX both on 462.7000 MHz, no TX CTCSS tone set). The third party does not hear it, nor does Radio B.
I send another audio transmission from Radio B (still set to use the repeater and CTCSS tone). His reply is received by both of my radios.
