WRYF792
    Maricopa County, Arizona
WRYF792's Achievements
  1. The radio has TX and RX, what's throwing me off is the club lists the tones as RX TL and TX PL, but they also show info for just TX and RX. Thank you for the info about the number though. That is incredibly good to know!
  2. I have reached out to the club, I do know that they have a lot of helpful members who are glad to help people like me, so fingers crossed! Worse case, somebody in the club has a cable I can borrow, because I agree, a computer makes programming completley painless! Sadly, I do not have a programming cable for the radio. I work at a dealership and it was in a truck we bought from auction, and they did not have the cable in the truck when they sold it. Pretty decent free find though nontheless!
  3. This radio shows nowhere in the menu for a PL or a CTCSS.
  4. All of the options when I push the menu button are as listed below: POWER LEVEL TX CODE RX CODE SQUELCH MIC GAIN REPEATER CALL TONE KEYTONE ROGER BEEP VOX TOT BACK LIGHT BRIGHTNESS SLEEP TIMER SPEAKER SELECTION With that all in mind, how will I know which one of those is the RX PL, the TX and the TX PL when those are what the club lists?
  5. I've got a RA86, and I'm trying to program some local repeaters for a local club. The club is very strict about keeping their repeater info private, so I will not be providing crutial information regarding this. However, the issue I am having is I cannot figure out what the RX, RX PL, TX AND TX PL tones would be displayed as on the radio. I've hit a road block trying to figure this out, so any suggestions, links or info would be wonderfully appreicated!
  6. I didn’t think of that! There was actually no issue with the radio at all. I had a UV-5R that was set to the repeater channel to see if I could hear anything from my GM-30. I know, this is frowned upon. But I’ve got limited resources for testing and only use the UV-5R to listen for my radio. Turns out the UV-5R was unsurprisingly unable to receive from the GMRS repeater. I could not set the tones on it. I ended up transmitting on my GM-30 asking for a quick radio check and instantly got a response. I’m still new in all this, so I come across small issues that are basically only issues due to my lack of knowledge or experience with the radios. Moral of the story is don’t use the wrong equipment to solve issues.
  7. If somebody could delete this, that would be great. I believe I've fixed this. I'm trying to set up a local repeater on my new GM-30, but I'm not having any luck being able to transmit on it. I've tried looking at everything in the Radioddity software, and I'm certain I've got everything correct, but it's just not working at all. It appears as if I have the latest firmware, and it just does not want to work. Does anybody have any knowledge of this radio or insight on the issue? I've tried swapping the TX & RX tones, with no luck, I've tried changing the squelch, and no issues at all. I did notice that I cannot change the step in the settings on the radio or in the software though, not sure if this is part of the problem or not.
  8. I went with my girlfriends dad to a local ham radio outlet because I got him interested in ham and GMRS. This anytone was one of 4 ht's they had they were selling as GMRS. My issue was 100% user error. It was setup with 3 beeps before transmitting, so I assumed this meant it was blocking me out from transmitting. User error is a killer for me! However, it was stupid how they shipped the radio with a total menu lock that per the manual, can only be disabled by programming the radio. Which gave me trouble because I wasn’t even able to disable this without updating the firmware first. I love the radio and I’d love to get one for myself, but that factory lockout is really annoying. Especially when you’re not expecting it!
  9. Does anybody know how to get the 878UV II Plus to work on GMRS? I’m not having any luck with it transmitting. Is there some sort of update or firmware you need to get it to work?
  10. I'm currently just using a magnetic mount antenna, the cable is far too short to make it fit in my car without having the passenger choked by the cable. I'd love to have a lip mount, but I have a small sedan that doesn't really have anywhere good for a lip mount, sadly. Thinking about just just getting this antenna, I've had good luck using one in the past. And it's small! https://www.buytwowayradios.com/midland-mxta13.html
  11. This didn't help my issue, I tried it last night and it was the same as using he "V/M" button on the radio, still locked me out of GMRS. I came across somebody who has also had this issue in the past, which provided instructions from AnyTone that did help solve the issue I had.
  12. I just wanted to post an update to anybody who is either wondering what ended up happening with me or for anybody out there who may be having the same issues I had. After doing a little more reading online and in this community, I came across a post talking about how sometimes this radio is shipped set for HAM only, which obviously is an issue when you're trying to buy a GMRS radio. Somebody in another thread had linked to an article about flashing the software to update it to be GMRS ONLY. Below is a link to the post which helped me out. I set this up last night and played around with the radio last night and on my way in to work this morning, and have had nothing but good luck having it work for GMRS since! I've gotten local repeaters programmed and am loving this simple small radio thus far!
  13. It is Version 2.30 - I just attempted the update from this post and I am now able to transmit on GMRS frequencies! I should note that at first it did not work, but then I turned the radio off, changed the mode in the V/M menu and now it works fine as far as I can tell! Now to figure out this repeater programming!
  14. I saw something yesterday about somebody saying they make the GMRS-only version, but I don't see that anywhere. However, your memory is correct, that is all there is too it
  15. I got it off Amazon
