Radioguy7268
    28
Everything posted by Radioguy7268
  1. You also have the issue that while DMR is a basic digital standard, every manufacturer has their own flavors that they have built on top of the standard to add features for their user base. So when one repeater owner decides to add Restricted Access for Security, and then another one wants to add enhanced Privacy/encryption, another will decide to implement GPS Location. Good luck trying to them all on board with your DMR dream. As already mentioned before - go get yourself an FB6 Private Carrier license on Part 90 if you want to do DMR. If you're determined that it needs to be done on GMRS frequencies - then go write up a petition for rule change & wait around for 5 or 10 years to see if the FCC responds.
  2. Brothers from another mother. Who's pulling DNA samples to check? But yeah, that's kind of flaunting it. Unless the Front Range EE group is one of those old Grandfathered commercial operators under Part 95 back from the days of Class A licenses...
  3. 40 miles is quite a stretch for a 4 or 5 watt portable to reach back to the repeater in most real world situations. I'd question why you think you might need 50 watts in order to reach 40 miles out, but you're not worried about the other half of the path - the repeater's receive side. If you need lots of power to reach out, how's that 4 or 5 watt portable going to answer back? If there's power in the building, it's probably 10 times easier to just use that. I don't think I've ever put a repeater cabinet outdoors on a building rooftop. Even if they didn't want to have us penetrate the roof, we could always find a way to wall mount the repeater inside & then sneak a coax cable out onto the roof. I have had to use non-penetrating sleds and find interesting ways to hide antennas so that the building architecture was not 'damaged' by the sight of an ugly exposed dipole. But solar power on top of a building that already had existing service? Nope.
  4. Who are you talking to and what do they carry for a radio? I believe you said you've got relatives 15 miles away. If they carry portables - it is MUCH more important that your desired repeater can hear those 4 or 5 watt portables from 15 miles away than it is for your desired magic repeater to punch out 50 watts so you can reach them. Pay more attention to how well your repeater can receive - and you'll end up with a better system. Wouxun mobiles built into a repeater are twice as expensive and half as good as other solutions available. Search up the term desense, and you'll see what's going on.
  5. Is there anything that limits an individual to one station? Many folks have multiple repeaters operating under one call sign. My nephew 2 states over uses my repeater (and call sign) to run his family farm.
  6. If you are talking to 4 watt portables - who cares how much power gets through the duplexer? A "tight" duplexer tuning that loses more dB is preferable to a sloppy duplexer tune job that gets more power/less dB loss. Remember, you are using the duplexer to achieve isolation between the transmit and receive frequencies. Isolation is your key measurement - NOT power throughput. On most of these rigs built with an inexpensive notch AKA compact duplexer and 2 mobile radios, turning DOWN the transmit power will result in better overall range, less desense, and longer equipment life.
  7. Radio waves don't know the direction in which they are heading - ie: being transmitted or received. The signal is the signal. The trouble you originally described would not be due to antenna height. Why go through the trouble of raising up the antenna, but avoid doing a simple 5 minute troubleshooting test and report on the results?
  8. The main reason 90% of repeaters use a duplexer is because of ISOLATION, not because of power loss. As others here have said, yes you can work it with 2 antennas, but you will likely still need additional filtering. If all you can measure is wattage & SWR, you are never going to appreciate what true isolation and improved receive sensitivity (and selectivity) can do for your repeater. How's that saying, when your only tool is a hammer, every problem looks like a nail? I guess in the radio world, when all you have is a watt meter, every problem looks like a lack of power. If you have enough RF power to reach out to whoever you want to talk with, but they can't reach you back because your repeater's receiver is being drowned out due to poor isolation (likely from your own transmitter) - then what's the point? You've now got a bunch of time and money invested in a one way paging system. The point of having mobile transmitters is to allow them to talk back. I'd gladly give up 3 dB of transmit power in a duplexer if it offered 100dB of isolation. Most of the affordable compact notch duplexers will only give you about 65dB of isolation with a 5 MHz split. Add a tuned bandpass cavity or two to the receive side, you'll pick up even more isolation - and you'll still be ahead of the 45 or 55 dB isolation of a split antenna system with 20 or 25 ft. vertical spacing. Oh yeah, and if you do a split antenna system, don't use braided cable for your coax. You'll leak somewhere around 6-10% of the signal with most decent brands - even worse with the cheap knockoffs that use a loose weave for the coaxial braiding. Think about where that 6-10% of your signal is going as it travels up the tower. Even the real Heliax hardline has some RF signal leakage, but it's about as good as you can get in an imperfect world.
  9. It's advertised as 11.9 dBi In a typical vertical collinear antenna, you can gain 3dB of gain every time you double the number of stacked elements - or you can just tell the advertising guy to add 3 more to the gain number by stating gain measured as dBi. dBi is gain measured against a theoretic isotropic antenna - which isn't the real world.
  10. OK, now I understand a little better about what you're asking. In my world, terminology of a "base" station means you are transmitting on the lower (462.x) frequency, and speaking in simplex to other people on the same 462.x channel. A Control station is what you use to work a distant repeater, and those transmit on the higher 467.x frequencies. Then they receive on the 462.x The appearance of a Base or Control station can be the same (a mobile radio on a desktop) but the programming and functionality would differ. You're not going to work a distant repeater by transmitting on the Base (462.x) frequency. If you have a repeater using a duplexer, you're not going to be able to do what I suggested (plugging in a mic) to do what you want. If you key your Control station on a 467.x frequency that's the same as your repeater, you're going to overpower the receive side of your repeater. Not recommended.
  11. If the two radios are not keyed at the same time, they should not interfere with each other. If the repeater and the base would be keyed at the same time, the stronger signal from the base would likely walk all over the repeater's output. Assuming you would be the one in control of the base radio, why would you knowingly create your own interference? I guess my biggest question is "why?" Other than being in love with the concept of a small 5 watt self contained repeater, you could just put in a larger and higher power repeater using the existing antenna & line that you've already got in place, and then plug a mic into the repeater so you could use it as a dispatch point. Pretty much every mid-range commercial repeater offers that option, especially if they're made from two mobile radios - like a CDR700 for example:
  12. Microwaves were invented during Roman times - Emperor Nero cut off some dude's fingers & left him with only his thumbs. That same guy (Digitalis Minimus) went on to invent the UHF PL-259 connector, for hams who were 'all thumbs'. True story.
  13. Double check your programming on both sides (repeater and mobile/portables). I'd think that it's more likely a fat-fingered typo than a problem with the antenna & line. It's either that, or you're describing a de-sense issue in a unique way... The suggestion of testing in simplex with another radio hooked up in place of the repeater is a real good test for basic troubleshooting. If a portable works just fine in simplex mode, then there's likely a problem with the repeater or duplexer. If you experience the same problem when testing with a portable - then you know you're looking at a coax/antenna issue.
  14. Assuming you don't need to hire a climbing crew to install that new antenna & hardline, then yes, the price of a 2nd antenna & line is probably much less than a tuned transmit combiner & receive multicoupler system. Having two repeaters close in proximity and close in frequency can lead to some issues if you're just using compact (inexpensive flat pack notch) duplexers that have very little protection from adjacent signals. Meaning that if you try to use the 462 GMRS repeater at the same time as the 463 Part 90 machine, you could create some of your own interference. If you're not keying both machines at the same time, then you're probably good to go. If you want to have both repeaters keyed up at the same time, you'll either need to use better quality filtering (think high end $1500+ bandpass/band reject cavity duplexer per machine) or a quality transmitter combiner system. Not many 'hobby' type systems can cost justify a combiner.
  15. You set Pin8 to PL/DPL - CSQ detect on the Repeater's RX (receiver) radio. This is how you make sure that only intended transmissions (from your group's properly programmed mobile/portable units) will be received on your repeater's 467.xxx frequency. The transmit radio is then being told to key up upon that receive decode action. There is no need for your Transmit radio to detect incoming PL/DPL. It's function is to transmit - but you should still generate a PL tone or DPL code for the Transmit output. Some people try to program the receive and transmit radios the same way - with the idea that they'll be able to swap them around more quickly once the transmit radio burns up. IMHO that's the wrong move. My take would be to program each radio for it's intended use, and set it up properly the first time. You can always save & store the codeplugs for later use to reprogram or re-purpose a unit via the Clone function. If you take the time to set things up properly - AND TURN DOWN THE TRANSMIT POWER - the repeater will live longer, users will be happier, and you will have more time to go about improving the system instead of thrashing around trying to figure out what broke this time. Repeater-builder.com is an excellent resource for anyone trying to build, setup, or program their own repeater.
  16. Well, First you should make sure that is what you want to do. From what you've said, it's possible that you're looking for a multi-tone panel to separate user groups on your repeater by PL tone. Adding an external tone panel to your repeater is not quite at the level of simple, but it has been done, and there are panels (and cables) designed to work with the Vertex EVX-R70 repeaters (and it's cousin the Motorola XPR8400). There's probably some online instructions out there on Repeater-Builder or similar sites. I'd peg it as a project for intermediate with skills to advanced/experienced. The inexpensive way for someone with experience would be to buy a good used tone panel (I've seen used Trident Raider panels go for less than $50 with free shipping on eBay) and find some online pinouts for crafting your own cable. You would also need some equipment to set deviation levels and repeat audio, and you would need to reprogram the repeater to function as a base with an external control panel. Without knowing your skill set, patience, and equipment - it's kind of hard to give a recommendation. Trading out your repeater for another unit that already has a Multi-tone function built in (Kenwood TKR) might be an option.
  17. You can certainly use an external controller & set it up like a community repeater with multiple PL or Tone groups. If that's what you want, there are other Repeater options out there with that feature built in, but a $75 or $100 used external controller will do the job. I doubt you would want to manually switch tone groups.
  18. There are ways to do channel steering through the rear accessory connector - and programming the GPIO pins, but I don't think I've ever seen anyone doing it on the lower end repeaters. As you discovered, there is no real reason to do anything more than 1 channel for most of us. Other than that, it's just legacy from the original mobile radios that are inside the box - and someone decided that advertising a 16 channel repeater was more impressive than just a single channel.
  19. I remember hearing an old timer story about the one time they got fined from the FCC - because they had a Part 22 transmitter that was BELOW the wattage specified on the license. The FCC had warned them, and they didn't take it seriously because... well, nobody ever heard of a fine for being below your allowed power. That story came about because we were brainstorming around at a dinner meeting during the early days of narrowbanding and refarming, and some of us saw the same opportunity for more available talkpaths in Part 22 if you did some creative channel splitting and re-use of offset frequencies. The old timer warned us that in Part 22, things didn't need to make sense but you did need to follow the letter of the law. Again, that was 20+ years ago and a different era with the FCC and enforcement actions.
  20. During that FCC Auction 20+ years ago, I attended an FCC Seminar down in DC & got to sit in with a bunch of people talking with FCC staff attorneys regarding the Auction process. One of the things we learned was that the FCC was only allowed to auction spectrum if there was more than one competing application for the allocation. That was the reason the attorneys always suggested that people checked the "all" button on their application, as they wanted to make sure that every market had a potential competing application. You did not need to bid on all the markets you expressed interest in, but without a competing application, the auction process could not legally proceed. Not sure if it still works that way, or if the FCC convinced the legislature to amend the auction rules. You would think that the concept should be to put the spectrum to use - rather than to just maximize Federal revenue. Google 1997 PCS auction defaults if you want to read up on some FCC comedy.
  21. More than 20 years ago, I got involved in an FCC Auction & made an honest effort to get some VHF channels in my economic area. The economic area I was interested in went for over $2.5 million for what amounted to about 8 possible channel pairs. Part 22 channels from back in the IMTS days were gold. Most of them around my area are being used for linked DMR wide area systems. There's even still some wide area Paging on the old VHF Part 22 channels. Not sure how much availability there would be if the FCC protected incumbent operations.
  22. Yeah, but the desense issue is huge with a compact duplexer. Even when properly tuned, if you over-power the transmit side, you are still introducing a weak but competing signal on the receive side that WILL reduce the talk-back range of your portables. Worst of all, your own equipment is what's producing the interference, and you probably paid more money to get all that interference!
  23. Or, spend $800 to $1000 and get a purpose built repeater with a decent receiver front end that won't desense, and cooling fans to boot. Public Service announcement: your "50 watts" won't perform any better than a properly configured 10 watt repeater when you are talking back in with 5 watt portables. Especially if you're talking through a cheap compact duplexer that's probably rated at 65 or 70 dB isolation (and that's when it's properly tuned).
  24. In a SHTF / Post apocalyptic scenario the bad guys you are trying to protect your family from are going to be keenly interested to know who is trying to move valuable items. Value can be subjective, but a couple of yahoos getting on their GMRS radios and talking in code is more likely to draw attention than to deflect it. I don't think I ever said that trying to protect your family was a bad intention, but the people with truly bad intentions are not going to care how good your GMRS code ettiquete is. You have fun though - and by all means, keep us informed of your progress and the best code words to use. Things have been dead over here on mygrms forums lately.
